Old 17th February 2014, 08:12 AM
I don't think that threaded hole you've blocked is Botang's, pretty sure BH is lower down where water can easily pool and just a hole covered in some thin paper-like material.
Is your car LHD or RHD and roughly what did you have to do to get access to that?
Old 17th February 2014, 08:16 AM
Car is RHD, you see in photo 3 and 4 the little round bit of tape, that was stuck over the hole.
Old 17th February 2014, 08:33 AM
I'm pretty sure that the first picture is the one that I've seen referred to as Botangs Hole, below outboard edge of the ECU box I think on RHD.
Did you have to pull the ECU box forwards to find and access Dezzys Hole? Or is it "just" taking off the cover across the base of the windscreen?
(Might investigate mine if its the latter and we ever get a fine day)
Old 17th February 2014, 09:17 AM
I can't get the ECU box out do you have to take all ECU's out and the cables that go though the grommet at the front?
This is the 3rd time i've had a look for this hole, if' i've not sorted it this time i'll empty a tin of expanding foam in under there
Old 17th February 2014, 09:40 AM
I'm sure there's a very detailed thread somewhere, maybe on AudiPages?
I know I've read it when investigating my PF leaks a few years back, but could have been archived.
This is Notorious' comment, but I think you've seen that already. http://forum.a8parts.co.uk/showpost....10&postcount=8
Old 17th February 2014, 10:35 AM
Dezzy, this is not Botang's hole. The hole you have fixed is positioned too high to actually leak.
Botang's hole is hiding below cracked mastic and leaking through cracked mastic, so you won't see it in the way you see it in first picture, because you need to scratch mastic a bit first, which will fall off and reveal Botang's hole. Only then you will see a picture similar to 1st picture in your list.
Old 17th February 2014, 12:21 PM
I can't see how the box is secured apart from 1 nut on a ali stud outside of the box at the front (that sheared off rather than undo)
Dezzy's / Guy's hole is easily found by taking the cover off ECU box and i took 2 ECU's out but left them connected to to the wires.
I don't understand why it wasn't pointed out before when Guy posted up his write up about it. Even Botang didn't say it's not the right hole
LINK
I'll have one more go at it failing that i'll pour concrete down there hopefully it'll find it's way down under the ECU box
Old 18th February 2014, 07:13 AM
Still have wet getting in, so that hole is deffo not the culprit.
Does anyone have any instructions on how the ECU box comes out to get access down under it? before i pour concrete down there
Old 18th February 2014, 07:30 AM
I wrote about it in the post where you took the picture from:
"It is possible to fix the hole without removing the box, you will need long tweezers, heat gun or hairdryer, methylated spirit or industrial adhesion promoter and high quality silicone or any industrial grade glue (Soudaflex is good stuff) in a cylindric cartridge, extra long nozzle for the cartridge, and a silicone applicator gun."
Edit: And you will need to remove plastic scuttle panel from windscreen to allow a bit of access, which is easy thing to do.
Old 21st February 2014, 06:02 PM
Alright between showers i have had another go at it. Very awkward due to the 2 pipes
digging around and i did find this
I took the bonnet strut off just to give a bit more access, sealed it with Sikaflex very messy and i managed to stab my self in the hand with a screw driver so that was a bonus.
ID:	7412   Click image for larger version
ID:	7413   Click image for larger version
