Old 8th April 2014, 09:19 PM
rs32 rs32 is offline
definitely get coil packs checked and watch out as quite often one will give up and the rest will follow swiftly afterwards.
Old 9th April 2014, 06:59 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Did VW do the recall on the coil packs like Audi did?
[center]
06 3.0TDI Quattro:
Options:
Old 9th April 2014, 06:26 PM
not AFAIK - I've seen countless V6 4motions (like mine) and R32s need them all doing but not heard of so many on the smaller petrol engines, but VW tend to do very little in terms of goodwill when they have issues like this.
I can't remember on these if the BERU make are the ones to go for, or avoid. Best to check with an Indy specialist. I think from memory I've ordered BERU in the past and had to replace immediately but I could be wrong.
Old 10th April 2014, 09:56 PM
Cheers guys, very much appreciated, will update you soon
