Old 16th May 2014, 06:05 PM
Dogzdinner Dogzdinner is offline
I will go out and check it again but I am certain it has 7 numbers on the DIS when I put it into semi-auto mode!
Old 16th May 2014, 06:33 PM
Yep, 7 gears!
Old 16th May 2014, 07:25 PM
Originally Posted by Dogzdinner View Post
Yep, 7 gears!
WOW
Old 16th May 2014, 09:22 PM
Not quattro? Maybe the CVT box...
Old 16th May 2014, 11:31 PM
Could well be....what's the best way to figure it out?
Old 17th May 2014, 12:57 AM
sarg sarg is offline
yeah, pretty sure the non-quattros are CVT, so are in fact ONE-gear, just a continuously variable one
The 7 speeds you refer to are artificial ones with CVT boxes, it's pure electric wizardry.
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 17th May 2014, 01:08 PM
The big question is....does it have a F125 sensor?
Old 17th May 2014, 01:29 PM
No CVT will definitely not have F125 switch, and I think none of D3's has F125 switch.
Old 17th May 2014, 01:50 PM
That's already been proven to be incorrect....the D3's do have a F125 we are just not sure if the CVT gearbox has it! See above.
Old 17th May 2014, 02:11 PM
My bad, did a search on Elsa for F125 and it came back with nothing for D3
