Old 25th May 2014, 11:19 AM
Bandycoot Bandycoot is offline
Default A couple of issues.
Issue 1. My central locking is not working. I did a scan and it appears that my key fob needs adapting or something. The Ross tech wiki has no procedure for this so can anybody help?
Issue 2. I inadvertently put the wrong code in my radio and it went into safe mode. I have the correct code but now I can't enter it. What can I do?
Thanks.
Steve.
2001 D2 S8. Volcano black. KW Variant 1 coilovers. EBC Turbo grooved discs with Yellow Stuff pads. 19 inch R8 replica wheels with 255/35/19 Michelin Super Sport. In the UK, 1990 Audi 90 2.3 20v Quattro with just 65,000 on the clock and in mint condition.
Old 25th May 2014, 11:27 AM
HPsauce HPsauce is online now
Wait 1 hour with the ignition on. That's it - says so in the manual.
You might get away with just the radio powered on for that time.
Old 26th May 2014, 05:31 AM
Thanks. I'll try it.
Old 27th May 2014, 07:14 AM
Right. Tried your suggestion, HP, and bingo! That's the radio working. Anybody any idea of setting my key fob up? Ta.
Old 27th May 2014, 03:37 PM
Try one of these depending on whether you have VCDS or second key.
at least 2 keys needed
http://www.audizine.com/forum/showth...i-flip-key-fob
with VCDS can do one key on it's own
http://www.audizine.com/forum/showth...mming-with-VAG
Old 28th May 2014, 04:56 AM
Brilliant stuff. Actually, I've been thinking. As I only have one key it may be that the fob battery is dead. I'll change it and see what happens. If I get no luck I'll go through an adaption and hopefully that will sort it.
Thanks
Steve
Old 1st June 2014, 03:45 AM
Sorted. I changed the batteries in the fob then just re-synchronised everything by pressing the lock button on the fob then locking the door manually with the key. This valuable information was found in the car instruction manual - which I should read more often when I get problems like this.
