Hi
Came to do my rear discs and pads yesterday, but I guess like most DIY'ers , I only have axle stands and a trolley jack. I abandoned the job as I could not see anyway to get my stand in once the car was jacked up. Job itself looks simple enough on outer inspection. Has anyone else done this job sucessfully on stands/jack please? ***oops*** this has gone in the D3 section - should be in the D2 section. I have a 98 S8 D2. Last edited by jools_s8; 10th August 2014 at 03:46 PM. Reason: wrong car - D2 not D3 |
I prefer to use different length logs instead of axle stands
Did the rear discs and pads a few months ago using the the car jack (but i I got a heavy duty jack to replace the standard one which collapsed when under load last year). I am not too sure whether the jack dimensions are the same but it is a struggle to get axle stands in under the jacking pads whilst using the jack on the side supports intended for the jack. I have two pairs of stands and one is slightly shorter than the other so, with a bit a squeeze, managed to place the shorter ones in the right place.
I usually just use the trolley jack and put the wheel under the sill just in case when doing brakes, never usually in there that long.
Thanks, going to have another go this weekend, using the OEM jack / stand and spare wheel in place, just in case.
http://forum.a8parts.co.uk/showthrea...ght=jack+death I
The only use I have found for the OEM jack is to slightly raise the car so that a proper (e.g. trolley) jack can be slid underneath to then lift using the pads.
Looking at the other thread about jacks it had these part numbers.
4D0 011 021B Armoured. 4D0 011 031F Bigger engine. And two others depending on chassis number 4D0 011 031D 4D0 011 031C for different jacks. David, what's the difference between the normal jack and the heavier duty ones? Any pics?
