Go Back   A8 Parts Forum > A8 D3 > D3 - Common Faults
D3 - Common Faults Quick links to all known common faults and their solutions
Old 28th August 2014, 11:33 PM
d.f. d.f. is offline
Where can I get a VCDS cable?
A new battery has been put on. I will report back with make and model.
Old 29th August 2014, 07:55 AM
mannyo mannyo is offline
Battery charge rate is controlled by the battery ECU. If the ECU believes the battery is fully charged, it will not pass the alternator voltage to the battery. You could have a faulty battery ECU. I would scan the energy monitor ECU For faults first, and then suspect the battery.
Manny
Past
Old 29th August 2014, 08:06 AM
Here is the link to VCDS cable http://www.gendan.co.uk/product_VCHU.html
Old 29th August 2014, 01:02 PM
One more question: do we have to put an an actual Audi battery on the car and then code it to the computer?
Old 29th August 2014, 03:05 PM
No, any brand will do as long as the charactersitics match the original, which is usually 110Ah or 95Ah. You can use the VAG equavalent part number or the VARTA part number. Y
ou also need to change the serial number in order to reset the accumulated battery data back to that of a new battery.
Old 29th August 2014, 04:07 PM
You can use the VAG equavalent part number or the VARTA part number. You also need to change the serial number in order to reset the accumulated battery data back to that of a new battery.
How do I do this?
Old 29th August 2014, 05:01 PM
How do I do this?
I used these instructions...
http://wiki.ross-tech.com/wiki/index...ry_Replacement
http://www.ross-tech.com/vcds/tour/r...n.html#battery
