Old 29th September 2014, 01:46 PM
Default FAULT: ESP/Steering Angle Sensor
Hi guys
I was changing steering wheel buttons and since I finished the ESP light won't go off.
After a scan I get the steering angle sensor fault, see attached
The procedure was:
- disconnect (-) on the battery
- pull the Airbag fuse out
and that's it really.
I did not disconnect any connectors other than the buttons connector, but on one or two occasions I may have pulled the airbag cable a little, is that what caused the problem ??
Thank you
