Old 17th November 2014, 07:30 PM
Half an hour if searching and searching through all possible controllers, adaptation, coding, long coding and nothing.
So far the patter is:
2x ACC wide dis clusters (coded out) - no MPH
2x non ACC wide dis clusters - MPH available
All 4 PF (<2009)
Will have to study the MMI's Hidden Menu document properly because after translating most of the options in Hidden Menu there is no obvious option which would enable MPG function
Manny, what the situation with yours??
You have a ACC cluster with ACC installed, can you switch to MPH on the main display (cluster) ???
Old 17th November 2014, 07:47 PM
mannyo mannyo is offline
I have no MPH display, or gear info display in my car with PF 2004 cluster and active ACC.
I'll be at the fairmile on Sunday hopefully, your more than welcome to scan my cluster and anything else to help in your diagnosis. I'd like the full MPH and gear display but its looking like it's not possible.
Manny
Past
Old 17th November 2014, 08:25 PM
Cheers Manny
3x ACC wide dis clusters (2x ACC coded out, 1x active ACC) - no MPH
Old 17th November 2014, 08:41 PM
Removal Guide added to the first post, half way down.
http://forum.a8parts.co.uk/showpost....52&postcount=1
