Old 7th January 2015, 07:40 AM
Am I right in thinking that you don't have to add the remote control function. You can get away with just the pump and pipe work?
You don't have to add the remote, and you could leave the shut off valve out but it would then always preheat the engine rather than just the cabin.
If you add the shut off valve you can add an adaptation to add another line to the MMI for Engine preheat ON/OFF.
Old 7th January 2015, 08:06 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
That's good.
The remote side is like £200 or something if I remember correctly.
[center]
06 3.0TDI Quattro:
Options:
Old 7th January 2015, 08:56 AM
audifin audifin is offline
I would say remote is a must, or even better, Webasto Thermo Call which enables you to start it remotely by sending a SMS text message to it
http://www.ebay.co.uk/itm/WEBASTO-TH...item35d68b94e6
http://www.webasto.com/int/markets-p...s/thermo-call/
Old 7th January 2015, 09:08 AM
ScottD3's Avatar
It would be very nice to have.
Get up, press the heat button so the car warms up while you're getting ready.
I love it.
[center]
06 3.0TDI Quattro:
Options:
Old 7th January 2015, 09:27 AM
SWMBO has it on her Nissan Leaf, it's pretty amazing Works in the summer too to cool it down.
Old 7th January 2015, 09:32 AM
I remember someone talking about a SMS activated relay to start the heater.
http://www.quantek.co.uk/GSM%20Remote%20Control.html
May be a cheaper alternative to the remote.
Mmmm all this heater talk has me thinking if it would be worth it on the S8
Old 7th January 2015, 09:40 AM
ScottD3's Avatar
If you do the Aux heater coding on the MMI you get the timer options for Aux heater and Aux vent.
All the vent does is turn your blower on.
Which does help but I'm always paranoid of it draining the battery.
Solar sunroof needed.
[center]
06 3.0TDI Quattro:
Options:
Old 7th January 2015, 09:42 AM
ScottD3's Avatar
It is worth it.
Group buy?
[center]
06 3.0TDI Quattro:
Options:
Old 7th January 2015, 09:56 AM
http://www.ebay.co.uk/itm/261633010631
I Think this is the pump, with the 90˚ inlet/outlet.
Old 7th January 2015, 10:06 AM
ScottD3's Avatar
Looks right.
Different plug but that's not really an issue.
[center]
06 3.0TDI Quattro:
Options:
