I am going to try a graphic interface between the screen and the screen control unit. Someone locally makes a unit fairly cheaply (100 pounds or so) that will do it and cut the MMI feed when the car is reversing.
I have just needed a camera. What exact one did you get that replaces a license plate lamp? Mike
04 A8 - 4.2 Sport Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension Auto Boot - Double Glazing - AMI - Solar roof TV - Bose - Voice Control - TPMS - AFS- TINT Power Blind, Fingerprint - Light package (in and out) Retrofits: OEM Auto headlights & rain sensing wipers OEM Bluetooth phone Bluetooth Audio Streaming Reverse Camera OEM Aluminium Package Auto boot close using remote/door button |
The MMI Control head take an LVDS video in - not composite. The RVC unit outputs LVDS . The TV unit outputs LVDS but the AUX in are composite. |
The underlined words in the following text are links. Left click on them and your browser should open up another page.
I used this camera:- CAMERA I also bought from the same supplier:- Tx/Rx Pair When ordering the camera remember to select the PAL version. The NTSC one would work but you would have to change the MMI setting on the Aux channel you use. This camera worked out of the box without any faults. I used the Tx/Rx to save running a video cable from the boot lid to the main body. There is also the possibility that I will purchase a CAR VIDEO INTERFACE or an X-CarLinK in the future to automate switching the MMI to reverse camera view on engaging the "Going Backwards Gear". Any problems just ask.
Ray at Wigan Pier 2014 A8L D4 4.0TFSI Gold (Sticker says "Beige") Can't leave you in a black smoke cloud anymore.. In progress, Nothing left to do. Gone 2004 A8 D3 3.0 TDI. Ebony Pearl Black (with little bits of other colours and glitter) Last edited by tc4332; 25th March 2015 at 06:38 PM. Reason: Checking that the links work as intended |
The LVDS that some people are talking about is when you are connecting direct to the MMI.
Because I have connected via the now otherwise redundant analogue TV Tuner the camera output can be just composite using a yellow plug/socket that is already fitted. Just plug and play.
Right Chaps,
I managed to buy the X-Carlink, the seller knocked £50 off for me 'cos I phoned him and had a nice chat. The manufacturer has done some updates, both hardware and software. It now does all sorts of video to the MMI screen and can pass audio to the sound system. I only want it for automating the reverse camera operation. The supplier said that it might now work with my Chinese PAL camera, and yes it did. ![]() Now fully fitted and working really well. ![]() Camera and transmitter/receiver pair as above. Camera and transmitter in the boot lid, both powered from reverse light supply. The LEDs in the camera body powered by number plate light supply. X-Carlink powered by a permanent supply and by an ignition switched supply. It also needs a reverse supply, this I took from the reverse light supply by tapping into the loom in the left boot space and running the wire through the car to behind the glove box where the X-Carlink is located. The receiver for the camera transmitter is also located there and is supplied by the reverse supply. SWMBO has not inspected it yet, but she will give it a good pass mark, really good colour picture, no interference and it switches on automatically. Whatever sound is playing carries on, only the video is replaced by the rear view. Engaging the backing up gear just does it all for me. ![]() Final cost just over £200.
Ray at Wigan Pier 2014 A8L D4 4.0TFSI Gold (Sticker says "Beige") Can't leave you in a black smoke cloud anymore.. In progress, Nothing left to do. Gone 2004 A8 D3 3.0 TDI. Ebony Pearl Black (with little bits of other colours and glitter) Last edited by tc4332; 8th April 2015 at 08:53 AM. Reason: Spelling mistake, Teacher belted me! |
