  #38
Old 2nd April 2015, 09:35 AM
While crankshaft position sensors do fail it is very unlikely they will both fail at the same time and engine would run with 1 failed, they also register fault codes if they are faulty. I think it's more likely to be fuel delivery issue, can you hear fuel pump running for couple of seconds when you switch on ignition?
Just checked the fuel pump this morning and ... nothing. Was going to check fuel delivery as shown in the Service Manual for the fuel supply system (on the Tech Dump) but as the drawing on P58 is different from what i see, i cannot identify which line is the fuel return hose and rather than start pulling stuff apart and given that it seems as if the pump is not working anyway I have decided to throw in the towel and my local garage is taking the car this pm. The fuel pump replacement/repair is beyond my time/capability at this moment in time.
