Hvac controls on my car appear to be coded for left hand drive but unfortunately there is no coding info or label files for it.
Is everyone's the same or is it just mine? You can find out by pressing the fan speed button on your side and see if it says driver or passenger
Del ![]() |
Mine certainly says Driver for Driver and Passenger for Passenger correctly for RHD. I did test drive another '8 where is was labelled for a LHD car but didn't think much of it.
I don't know if this coding from an A6 may help? http://wiki.ross-tech.com/wiki/index...rom_MY_2002%29
Try this Del,
Go to the MMI secret menu (car+setup) Go to Diag Settings Uncheck Linkslenker (this is the setting for left hand drive vehicles) Restart the MMI Climate control should be back to the settings for a right hand drive car now!
No idea how you found that out Matt but your bang on it.
Cheers fella, I love this forum Don't suppose you have a label file for 08 hvac do you Btw I got your nav disk installed after removing the DVD lock, works a treat.
Del ![]() |
Excellent!
Not sure about a label file, is this what you want from VCDS? Code:
Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 A Component: KLIMAAUTOMAT 015 0240 Revision: 00000018 Serial number: 00000000023996 Coding: 1069057 Shop #: WSC 02311 785 00200 VCID: 5ABB8B6F950D75F140B-800F No fault code found.
See where it says label none, that means there is no tags for the info coming out when using measuring blocks.
Its a pain, when trying to fault find A/C for example. There's quite a few controllers that don't have labels and it bugs the OCD in me TBH
Del ![]() |
You can make your own label file.
Use ELSA for what each section is, add it to a file and your done. I hate not having label files.
