Old 19th April 2015, 10:21 AM
barzya8 barzya8 is offline
Default PF 1997 Front Brake Disc Size
Hi All,
Does anyone know what size/thickness front disc I have on my car.
The code in the service book shows it as 1KE, which I believe is the 269mm size disc.
Are the disc the same size for the front and rear, as my fronts are well worn after 170,000 miles of use and need replacing urgently.
There is also heavy squeeking on normal braking coming from the fronts
Also, can anyone recomend cheapish Branded replacements from Euro Carparts
Thanks,
David
Guildford, Surrey
Bose sound system.
Audi Navigation Plus.
20 inch Final Edition alloys
Old 19th April 2015, 12:20 PM
Front disks will be either 323x30mm or 314x30mm, 323mm was used on S8 and some A8's, 314mm was usually used on smaller engine cars. Rear discs will be either 269x20mm or 245x10mm more likely to be the bigger option, if they are vented they will be 269x20mm, on the front only 100% sure method is to measure them, 1LC should be 314mm, 1LX 323mm but I would not trust it 100% without measuring.
Wit the the current exchange rates to euro it makes sense to check German prices.
I recently replaced fronts on mine, cheap and decent front pads for 323mm front discs here: http://www.ebay.co.uk/itm/1412284893...%3AMEBIDX%3AIT
I went for coated zimmerman discs to slow down corrosion if you need 323mm here: http://www.ebay.co.uk/itm/1816037995...%3AMEBIDX%3AIT
Old 20th April 2015, 04:31 PM
Many thanks ainarssems.
Have ordered the correct ones now 314mm.
David
Guildford, Surrey
Bose sound system.
