Old 28th April 2015, 06:53 PM
Well my experience of main dealers and filters was less than ideal, they replaced the filters but what I can only assume is laziness was to pull the filter boxes out of there mountings to make access easier for one screw and didn't put it back, so the intake pipes didn't line up, and i also found the hose clip that holds the air intake pipe to the throttle body was left slack.
Anyway back on topic yes I would say they were manky, treat the ol girl to a fresh set
Name:	2015-04-25 11.48.28.jpg
ID:	10638   Click image for larger version
Name:	2015-04-25 11.26.10.jpg
Old 28th April 2015, 07:14 PM
That must be so frustrating Del especially if the dealer is the one place where this simple job should be done with no issues whatsoever.
I went with Green Filters http://www.greenfilters.co.uk/ and since then, 3 years ago at least I'm just keep cleaning it every few months and its not far from as good as new, but in all fairness I'm not doing ridiculous miles or drive outside city streets and main roads.
Old 28th April 2015, 07:56 PM
Burnzybubbles's Avatar
I don't know if I posted it on here but there was an interesting test done on types of air filters, and unless the filter is a known weak spot or restriction then they didn't give enough benefit to outweighs the cons of the fact they let more dirt into the engine, I'll see if I can dig it up for you too have a read.
Here you go: http://www.bobistheoilguy.com/airfilter/airtest1.htm
Old 29th April 2015, 01:59 PM
tipptop tipptop is offline
Just did my air and diesel filter yesterday. Air filter looked as bad as yours. Car has 170k miles and no mention of diesel filter in the service history. Got both filters from audi with trade discount for €110. The diesel filter i cut open afterwards and out spewed some very dirty gunge. The paper filter inside was covered in a slimy gloopy sludge aswell.
I had a slight shudder throughout the car at low revs, most noticable at 70-80mph even on glass like roads, I was convinced there was a gearbox issue and was lining up a fluid change. The shudder is gone after the filter changes so i guess it was partailly blocked and starved of fuel at low revs.
A lesson to start simple!
A8 D3 3.0tdi quattro 2006
A6 C5 1.9tdi 2004
A4 B5 1.9tdi quattro 1997
Old 29th April 2015, 02:11 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Hey that's interesting. I have a very slight shudder between 50-60 mph. I've had the wheels balanced/checked and a 4 wheel alignment (checked, and it was fine) and replaced all four tyres, still there, very slightly, and bugs the s@*t out of me.
How easy was the diesel filter to replace?
2007 Mini Cooper S R56
Old 29th April 2015, 02:34 PM
It seriously bugged me too. I only had the car a few weeks and put the shudder down to mixed brands and thread depth on the tyres. I got 4 new dunlops and alignment and balanced twice. Still had the shudder. I felt it most in the accelerator pedal and a little in the gearstick and the passanger seat back would vibrate. Basically ruined the comfort for me anyway.
The diesel filter is easy. Fill the new one with diesel, slap it in, few cranks and it will start again. You could even fill the new filter with a fuel system cleaner like dipethane or stanadyne to give the injectors a good blast.
My shudder is gone, much more responsive too. Im thinking it was the original filter in the car after 170k miles
A6 C5 1.9tdi 2004
Old 29th April 2015, 02:19 PM
Johnmed's Avatar
Originally Posted by Burnzybubbles View Post
Was there not a date stamped into the filter?
I'd say it looks like it hasn't been changed in a while but it all depends on where your driving, I have noticed the d3 is quite good at scooping crap into the air filter housing, iv also noted what a crap design it is, my opinion is it hasn't been changed in quite a while, wouldn't be the first time any main dealer hasn't bothered changing all the filters.
Didn't see a date on it. I still have it (in the wheely bin) if anyone knows where to look for a date exactly.
Good read
Old 29th April 2015, 08:09 PM
Good read
Take a picture of the top with the black writing and post it on here, not all have a date but a lot do, if you look on the top of the man filter it's on there since the design is the same I'd be surprised they aren't the same manufacturer.
Old 30th April 2015, 04:22 PM
Johnmed's Avatar
Ta da:
Old 30th April 2015, 07:24 PM
It's not there, sorry for making you drag it out the bin, if you look on this photo next to made in Germany is the date stamp, funny why they don't put it on the Audi part :\
