I recently had problems with no label files for my engine but the work around was renaming the r8 files.
In your case there is german lbl files so either you can read german and your laughing or go through these two files and google translate it then save into your label folders and you should be good to go
Del ![]() |
Thanks dell your a star, I did look into it and tried a label file from another 3.0tdi engined car and renamed it to coincide with the A8 file but to no avail ![]() I certainly can't read German so it'll be google translate then ![]() ![]() |
They are for the 4.2 BVN engine, but if thats not what your looking for google german vcds in stall it and navigate to the folder with the label files to find the ones you need
Del ![]() |
Thats weird you are correct there should be 057-910-409-BVN3.LBL as well as the too that I posted but also like you said its still missing all the critical info and appears to only have the adaptation and coding info
Del ![]() |
Mine is using this...059-907-401-ASB.clb
It came with VCDS Version: 15.5.0.0 (x64) I attached it Last edited by snapdragon; 23rd April 2020 at 08:19 AM. |
cheers guys.
as for what to monitor and report on, do you have any hints which group [from 001...019 under Engine or Engine ii] I should select and I will provide/post relevant info here? Much appreciated. |
