Old 13th July 2015, 10:08 AM
andycaca andycaca is offline
unplug the tv unit in the boot and then plug it back in again?
2001 S8 D2
Old 13th July 2015, 10:03 PM
goldsax goldsax is offline
thanks for the reply.
still no joy.
tried searching the net, for hard reset and found that there is a way to ‘hack’ into the unit.
but feel a bit uneasy is the post warned that it could go wrong.
i wonder why its so hard/impossible to do a hard reset..
Old 14th July 2015, 06:25 AM
Have you checked the fuse for the TV Tuner?
Old 15th July 2015, 08:37 PM
disconnected battery for 10 minutes.
reconnected and the RNS works perfect.
wonder what happened?
thanks all for taking the time to help with this problem.
cheers
raj
Old 15th July 2015, 09:15 PM
Did you not try this?
Find the relevant fuse and pull it for a short time then re-enter the code; I've had to do that a couple of times in the past to reset my RNS.
Not 100% sure where the fuse is, on PF it was in the boot above the battery.
Old 16th July 2015, 05:54 AM
yes, pulled ,i think, fuse 36/37?
it would seem that by disconnecting the battery to make the RNS work, i pulled the fuse for RNS but there is probably a separate fuse for the TV/CD that i did not know existed.
cheers raj
Old 16th July 2015, 07:53 AM
Interesting, thanks for the clarification.
There has to be power for the CD changer too, never needed to look at that though.
Old 16th July 2015, 03:16 PM
According to my manual relevant fuses are:
Drivers footwell: carrier 3 (yellow) # 2, carrier 4 (blue) #5 and #6
Boot: 3A and possibly 4A (if present)
As noted earlier, I have pulled a fuse in the boot in the past.
