Old 16th January 2019, 12:37 PM
I'll be able to live-stream it now I've upgraded my broadband too
Turns out the reason my X carriage failed was because I was hanging a massive part cooling fan off the hotend mounting bosses, and they just aren't up to the job. They're aluminium nutsert-type things pressed in to a thin aluminium plate so really only strong enough to hold the hotend. All my fiddling and swapping parts etc has just stressed them beyond their service life - apparently its a known issue, but bizarrely I can not find a replacement carriage anywhere in the UK. There's only one site in the US which lists it, for a whole $5.
I have managed to bodge it back together with bits of PC case and cable ties for now so it will print again, and I've designed a new carriage which I will make from thicker aluminium plate. This will be much stronger, include a strain relief for the hotend wiring, and include mounting holes specifically for the larger part cooling fan so it doesn't hang off the hotend any more. I'm pondering getting the plate laser-cut for accuracy but I may just make it by hand in the workshop, depending on how long the bodge lasts
Old 16th January 2019, 01:13 PM
Wouldn't that be slower than watching paint dry?
I think I'll wait for the time-lapse videos.
Old 16th January 2019, 01:29 PM
Blooming Heck MJ, well done.
Thanks for keeping us in the loop. Hope the bodge lasts.
We now know not to put anything heavy on the carrier.
We are talking about using a self feed extruder just to get rid of the bowden cable.
Old 16th January 2019, 01:58 PM
The bowden is fine - its the big parts fan I was using, and probably mostly the fact that I did a lot of messing about swapping components and fiddling with the hotend which broke it. Nozzle swaps put a fair bit of load on those bosses too and I've done a lot of messing about with those too.
The heatsink cooling fan is really quite a bad compromise on the CR-10 since it also blows on the hotend. That means less stable print temperatures, more energy used to keep the hotend hot, and a limitation of max print temp (also the PTFE limits that). By changing to something like a fang cooler with a ducted fan on to the heatsink you get more even part cooling and keep the heatsink cooling air off the hotend. By also changing the cheap basic PTFE to Capricorn tube you can then print to the CR-10's maximum of 260C easily. It makes a big difference to complicated parts with lots of overheads and also opens up a wide range of materials.
I'm going to redesign the cooling fan I was using, but there are others which don't attach to the hotend heatsink and so won't cause the same problem. My new X carriage will be plenty robust enough either way
Its funny, at the top of the previous page I was saying the CR-10 can't really print anything other than PLA. Mine has subsequently printed PETG, CPE, ABS, ASA, and will be doing nylon as soon as my tufnol sheet gets here I might even try PC and some of the interesting alloys. The only thing I'm not trying to make it do is flexibles as noted in the Ginnam's thread.
A direct extruder will help with flexibles, and also filaments which have problems with oozing like PETG, but I'm not convinced its worth it on the CR-10. That may be because I'm quite happy to simply build another printer to do things the CR-10 is not good at. The Prusa mk3 for example does have a direct extruder using an E3D V6 hotend, and that's pretty much the reference machine of the cartesian market. But, its known to have clogging problems with things like carbon-filled filaments because they stick to it's all-metal hotend. The CR-10 with it's PTFE hotend will print those filaments absolutely fine. It really depends if you've run in to a specific limitation of the bowden setup tbh. If not, there's little to gain.
Old 17th January 2019, 08:00 AM
gninnam gninnam is offline
Sounds like you are having loads of fun
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 17th January 2019, 08:09 AM
Best toy ever!
(even better than the lathe and milling machine, and I never thought I'd say that!)
Old 25th January 2019, 06:43 PM
Well the Hypercube kit finally arrived from Ratrig (two weeks to get here from Portugal) and I have to say I am pretty underwhelmed. The extrusions are cut very accurately, but the angle brackets for joining the extrusions are straight outta Shenzhen They're supposed to have little tabs on them which align them with the grooves in the extrusion, but these are just tiny stumps which do nothing so its really difficult to get the frame square. By contrast, the brackets I printed for the CR-10, on the CR-10 are far sturdier and dimensionally accurate. I would have been better off printing the brackets for the 'cube while waiting for the extrusion to turn up.
I'll probably still order the extrusion for the Evo from them when the time comes since they're the only European supplier of black 3030 I can find, but I will source or print the hardware myself.
Pics of the frame later
Old 25th January 2019, 07:07 PM
Not 3D printer related but I am still waiting for some small parts to arrive from Lithuania that I bought on e-bay 2 weeks ago. But LEDs that I bought on Aliexpress arrived in 3 days from China. Maybe we will get better shipping times from EU when we are out of it.
Old 25th January 2019, 07:34 PM
It's all a bit of a bugger.
I ordered some tram bits from the only manufacturer who resides in the States. Ordered before Xmas and finally emailed him this week. Prompt reply, All manually made so it takes time to fulfill the orders.
Thanks for letting us know about the right angle brackets, probably like the plastic ones in MFI days. That is if you remember MFI.
We're looking at an Evo but on the higher side. Auto levelling, maybe tool changing, or multiple extruders feeding the one nozzle.
All pipe dreams at the moment just like my self dreiving trams.
Old 29th January 2019, 10:20 AM
New preferred supplier of extrusion: https://ooznest.co.uk/
The anodising is better, the ends are cut much cleaner with no burrs, and custom lengths turned up next day Better in every way than Ratrig.
Only downside is that they don't have 3030 so no good for building an Evo, but they do have 4040 for building a monster
