D2 - Everything else Anything that doesnt fit elsewhere |
#231
Interesting, though not exactly the same as my symptoms, nonetheless very similar.
It all points to the F125 switch causing odd behaviour that doesn't throw an error. One interesting test that you might be able to do is to set a cruise control speed at some point early in a journey (say about 35mph) and then when the symptoms appear at a lower speed turn cruise back on once at/over 25mph. In my case this instantly (without moving my right foot) reinstated full power mode.
#232
Just to add to that theory, there was a note on a service record for my S8 that the previous owner reported an unresponsive throttle.
Camspec didn't detect an issue during the time they had it for cambelt etc, but when I bought the car soon after I had the F125 flag up. As I changed it pretty soon after first detecting it, it might explain why I never experienced the poor/non-existent throttle response to connect the potential causes of issues together?
#233
![]() Quote:
#234
![]() Quote:
Further diagnostics needed ![]() |
#235
I find that that error is always in ABS unless you press brake pedal after switching on ignition. So try that- switch ignition on, press and release brake, connect VCDS and scan ABS for fault codes, brake switch error should not be there.
#236
Will do thanks
#237
That's weird - never had to do that with mine? Maybe it's a PF thing?
#238
![]() Quote:
![]() (I think Ross-Tech have a note on it somewhere) Quote:
#239
![]() Quote:
#240
Mostly normal service resumed
![]() When I fitted the replacement brake switch I got it in the perfectly wrong position (yes, there is such a thing!). It has two contacts - one normally open (for the brake lights), and one normally closed (for the ECUs). The ECUs expect to see both contacts change together so they know the switch is working. I'd managed to get it in just the wrong position so the normally open was open, but just enough pressure on it for the normally closed to also be open! The ECUs knew something was up so all got in a grump ![]() ![]() ![]() Curiously the cruise control still isn't working, despite the ECU seeing all the switch contacts operating, which is odd. Need to do a bit more digging on that. No brake switch error code on power-up either, so that must be a PF thing ![]() |
