Old 5th April 2019, 02:46 PM
gninnam gninnam is offline
They are Maine Coons They're about a year old in the pic. They are both considerably larger now!
Cheers - she did say they look like Maine Coons and wants one but I told her not until the current cat passes away
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 6th April 2019, 02:43 PM
So Stephen, whilst your car was a notable winner of several accolades, underneath it all it was a right mess....
After saying that I'm now afraid of arranging an appointment with Dr D2 in case mine turns out worse
Old 6th April 2019, 03:04 PM
Maybe there should be a 'best engine bay' award this year!
Old 7th April 2019, 12:15 PM
It’ll be between me and Stephen, then!
Old 9th April 2019, 07:53 PM
As this is a Mackie's gearbox, I'm not touching it I contrived this arrangement to replace the ATF lost when the cooler lines were removed from the radiator. Attach the lower cooler line, pour ATF in the funnel until it stops taking it, then put the upper line back on.
Both CV boots needed replacing
Clips removed
Cut the boot in half and remove it
A sharp whack to the centre of the joint with a chisel and lump hammer will pop it off the circlip
Slide the joint off the splines
The circlip is on the left. The plastic bushing and cup-spring on the right hold the joint tightly on the splines. These all get replaced
With the hardware removed, I put a plastic bag over the splines so the boot slides on without getting caught on any sharp edges
New circlip, bush and cup-spring
Rotate the shaft to vertical for the next bit
New grease
The joint is just sitting on the end of the spline now
Put a spare bolt in the end of it to use as a drift
Another sharp whack with the lump hammer knocks it over the circlip and it's locked in position again
The new boot is held in place with the proper crimp clips. Any mechanic who uses cable ties on CV boots should have his tools confiscated
This is the proper tool for crimping the clips
On to the other side. Not only was this boot held on with a cable tie, but whichever donkey had messed with it had beaten on the outer joint with a hammer and not bothered to to replace the bushing or cup spring so the joint was loose on the spline I assembled it properly of course. It is trivial to do this stuff properly, and a OEM GKN Lobro CV boot kit is £10. Why bodge it?
ID:	21287   Click image for larger version
ID:	21288   Click image for larger version
ID:	21291   Click image for larger version
ID:	21292   Click image for larger version
ID:	21293   Click image for larger version
ID:	21294   Click image for larger version
ID:	21295   Click image for larger version
ID:	21296   Click image for larger version
ID:	21297   Click image for larger version
ID:	21299   Click image for larger version
ID:	21300   Click image for larger version
ID:	21301   Click image for larger version
ID:	21302   Click image for larger version
ID:	21303   Click image for larger version
ID:	21304   Click image for larger version
ID:	21305   Click image for larger version
Old 10th April 2019, 08:45 PM
When I pulled the front panel I noticed that the radiator air guide speed-nuts were getting pretty crusty:
I keep these in stock so replaced them
The undertray hardware was missing, broken or bodged so replaced it all with new genuine hardware
The electronics box needed the usual repair
Engine bay all done
Interior stuff again - the centre vent was broken
The pin had broken off the end of the slat
I'd got to about this point when Jim arrived!
I brought Jim's in for a quick triage at this point so took a pic while they were all out in the sun together
ID:	21333   Click image for larger version
ID:	21334   Click image for larger version
ID:	21335   Click image for larger version
ID:	21336   Click image for larger version
ID:	21337   Click image for larger version
ID:	21338   Click image for larger version
ID:	21339   Click image for larger version
ID:	21340   Click image for larger version
ID:	21341   Click image for larger version
Old 11th April 2019, 07:50 AM
Great work!
Seems a bit drastic for a single broken vent slat!
Old 11th April 2019, 08:30 AM
27litres's Avatar
27litres 27litres is offline
Michaela,
Going back to the chain tensioner pads, you were saying that you cable tied the exhaust cam to the cam locking bar to stop it trying to move 15°...
It's my understanding that the cam gears are held on a taper, so I've got two questions;
1. How did you keep timing while you pulled the timing belt cam gear off?
2. With the cam gear removed (and the locking bar locating bushing presumably removed with it), what did you attach the locking bar to to keep timing?
I'm missing something here I'm sure! Does the locating bushing go back on and is it keyed or something?
I'll have to do this job eventually on mine, so I want to know how to keep timing when removing the cam timing gear.
It's something I expect I'll learn during the head reassembly on the Silver car!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 11th April 2019, 03:43 PM
Yes I'll snap a couple of pics to explain.
Old 11th April 2019, 08:14 PM
Cam stuff:
This is the cam sprocket attached. As noted, its a taper fit on the cam so held on by the torque of the bolt.
This is the locking plate. Both cams have flats milled on to them such that the locking plate only fits one way round, and its sandwiched between the sprocket and the washer under the bolt head.
This is the locking plate and bolt in place without the sprocket. The locking plate is loosely pushed on to the flats on the cam and then the bolt holds it in place
The right hand bank 1 cam will happily just sit there with no belt or sprocket. The left hand bank 2 cam though will rotate clockwise with very little provocation (especially on the V6), but generally won't move when you just take the belt off so its simple enough to dismantle everything to do the belt without it escaping. But, as soon as you loosen the inlet cam and chain tensioner, it will jump round on its own thus I keep the bar in at all times except when removing or refitting sprockets, the belt, or the water pump (because the bar gets in the way). Its not that important when only doing the belt though.
The engine in this pic ^ is sitting on a pallet with no timing gear and both cams are still lined up. When I pull it apart to do the tensioners, that's when I'll put the bar pack in
ID:	21358   Click image for larger version
ID:	21359   Click image for larger version
