Old 14th February 2013, 05:01 PM
Default Erratic throttle response when cold
I'm still trying to get a good feel for what goes on and when, but this is what I've noticed so far - more than once in each case:
1. Driving away from my house when starting the car from cold usually involves reversing out then driving off uphill, a definite hill but not especially steep.
I've noticed the car surging then slowing then surging forward again without me changing the position of my right foot. "Kangaroo petrol"
(I may have experienced this elsewhere but not 100% sure as I'm usually driving away gently on level ground)
2. Pulling out of a side road and accelerating the car only speeds up "gently" not "urgently" as I expect. No ABS/ESP warnings or symptoms. Only seen within the first minute or so of driving the car and not always by any means.
I haven't yet tried starting it on the drive and gently pressing the accelerator pedal to see if revs vary.
Problem #1 is a bit weird but #2 is potentially quite dangerous.
No codes showing on VCDS. No "slipping" or increased revs, just varying power so I suspect engine-related not gearbox.
It's an FL S8 which I understand is "fly-by-wire" though what the relevant components are and where I don't know.
Suggestions please on possible causes and how to diagnose.
