Old 1st October 2014, 08:00 AM
Mikey-S Mikey-S is offline
Default For sale: Brand new D2 S8 rear gearbox flange - new type
I bought this to cure the leaky rear flange seal, but upon pulling it apart I found it already had the updated flange fitted - turned out to be a damaged seal! Anyway I paid £120 for this as it came from the states, so I want back what I paid for it, plus delivery. I can take it to ADI if needed. Please PM me if interested, thanks.
Old 5th October 2014, 08:03 PM
Just a couple of photos .. I'm sure this is ££'s cheaper than buying from the dealers or TPS! Part number 01V 409 809A
Old 30th October 2014, 12:35 AM
Bump
Old 20th January 2015, 03:07 PM
Still here. Will take £105 delivered.
Old 22nd January 2015, 11:48 AM
Why did you need one of them out of interest ? Not something that normally sees any wear. Sorry have just read your 1st post properly..
Old 22nd January 2015, 11:54 AM
It's a fairly common fault with the D2s. Audi made a modified seal (cheap) but you also need the modified flange to fit it (expensive).
Old 22nd January 2015, 02:52 PM
But as I and Mike found, if your car is late enough it seems to have been an undocumented running change....
Old 22nd January 2015, 03:03 PM
Yes! Found that out the hard way..
Old 22nd January 2015, 03:09 PM
If its undocumented is there anyway of knowing whether you have the new type flange/seal? (My S8 was registered July '02)
Old 22nd January 2015, 05:17 PM
I don't think so. You will need to pull the flange out to see if it has the recess for the new type of seal.
