#31
Thanks guys, will get out there in a sec and report back!
#32
You done it yet
Remember to go to each module one by one after full scan and clear faults individually. Sometimes you've got to jump ahead a bit, if there is fault in ABS ECU reported in engine's ECU you will have to clear ABS faults first and then go back to engine's ECU to clear the message and ABS faults. You still doing it?? What takes you so long
#33
OK, got VCDS to accept new coding for the battery - sorted
Cleared all the codes manually after doing a full scan while running, locked and left the car, went back and there is this little lot: Friday,23,December,2016,00:43:59:44654 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 16.8.4.2 (x64) Data version: 20161129 DS267.0 www.Ross-Tech.com VIN: WAUZZZ4E78N003545 License Plate: Mileage: 110800km-68847mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 1D 1E 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77 VIN: WAUZZZ4E78N003545 Mileage: 110800km-68847miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E0 910 552 G HW: 4E0 907 552 Component: 5.2L V10/4V FSI ™0020 Revision: 5AH15--- Serial number: AUX3Z0G9332471 Coding: 01060003190F0160 Shop #: WSC 02313 785 00200 VCID: 264279329149637293-8072 No fault code found. Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E2 910 156 C HW: 09E 927 156 B Component: AG6 09E 5,2 FSI RdW 0030 Revision: --H04--- Serial number: 0113762 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2446633AE77591628D-8070 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 K HW: 4E0 614 517 BT Component: ESP 5.7 allrad H49 0650 Coding: 0001627 Shop #: WSC 02313 000 00000 VCID: 2B5488068AAB5E1A4C-807E No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 907 181 A Component: FBS AUDID3 H12 0200 Revision: 02005112 Serial number: AUX3Z0G9332471 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BE07CAEBBD0582D1-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 1 Fault Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 0 Reset counter: 25 Mileage: 110800 km Time Indication: 0 Date: 2016.12.22 Time: 15:35:58 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 785 00200 VCID: 2446633AE77591628D-8070 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300JT077588153 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 3A7ABD4275F1F792C7-806E Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0050 Subsystem 2 - Serial number: 00000000047342 Subsystem 3 - Serial number: 0108.10.070000000100010149ˇ Subsystem 4 - Serial number: 010149ˇ 1 Fault Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 240 Mileage: 110807 km Time Indication: 0 Date: 2016.12.22 Time: 15:29:54 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000132966 Coding: 0123001 Shop #: WSC 02311 785 00200 VCID: 1C365BDADF05A9A235-8048 2 Faults Found: 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 240 Mileage: 110788 km Time Indication: 0 Date: 2016.12.21 Time: 01:45:37 Freeze Frame: Voltage: 12.00 V 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 239 Mileage: 110788 km Time Indication: 0 Date: 2016.12.21 Time: 02:00:00 Freeze Frame: Voltage: 14.30 V ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 S HW: 4E2 955 113 C Component: ILM Fahrer H16 0240 Coding: 0133121 Shop #: WSC 02313 785 00200 VCID: 387EA74A4BFDE58231-806C Subsystem 1 - Part No: 4E2 910 113 C Component: Wischer WWS D3 H60 0440 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH04 0002 Coding: 00141886 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00481 210 83110 VCID: 2B5488064AAB5E1A4C-807E No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: None Part No SW: 4E0 910 563 C HW: 4E0 035 563 Component: DAB-Tuner H41 0830 Revision: 00000001 Serial number: KE1276V7600354 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2446633AE77591628D-8070 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E0 910 552 G HW: 4E0 907 552 Component: 5.2L V10/4V FSI ™0020 Revision: 5AH15--- Serial number: AUX3Z0G9332471 Coding: 01060003190F0160 Shop #: WSC 02313 785 00200 VCID: 264279329149637293-8072 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 E HW: 4E0 959 655 K Component: Airbag 9.41 H01 4210 Revision: 91H01421 Serial number: 003CU000228E Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 285E770A9B5D7502A1-807C Subsystem 1 - Serial number: 63328RB402F082A1G Subsystem 2 - Serial number: 63428RB402F08303A Subsystem 3 - Serial number: 63528RB402F08308G Subsystem 4 - Serial number: 63628RB402F082A8Q Subsystem 5 - Serial number: 63729RB402A9C855Y Subsystem 6 - Serial number: 63829RB402A9C84D% No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 A HW: 4E0 953 549 C Component: J0527 0410 Revision: 00H05000 Serial number: 90054072580024 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: 264279329149637293-8072 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H02 0100 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 951 M HW: 4E0 920 951 M Component: KOMBIINSTR. VDO H83 0620 Revision: D03 Serial number: AUDID3G9000135 Coding: 0048423 Shop #: WSC 60756 001 1048576 VCID: 2F6C9C16BEB3223A60-807A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.clb Part No SW: 4L0 910 468 A HW: 4L0 907 468 B Component: J533__Gateway H06 0060 Revision: 00H06000 Serial number: 1100B07A0183FF Coding: F5F59FFF707E1E00 Shop #: WSC 02313 785 00200 VCID: 2D50861EB4BF502A52-8078 No fault code found. ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 A HW: 4E2 905 218 B Component: FPI_1 H01 0020 Revision: 01000102 Serial number: 10102007110845 Shop #: WSC 00000 000 00000 VCID: 1F4C6CD6CE13B2BAD0-804A No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 E HW: 4E0 035 110 A Component: MP3-Changer H46 0390 Revision: 00046006 Serial number: AUZ5ZBG3498338 Shop #: WSC 00000 000 00000 VCID: 1A3A5DC2D531D79227-804E No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 D Component: KLIMA-STG. FOND 017 0230 Revision: 00000020 Serial number: 00000000060119 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 61C82A2EB8E7C44AA6-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 L HW: 4E0 907 553 H Component: LUFTFDR.-CDC H07 6340 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2C568B1A8FA5592245-8078 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063342 Shop #: WSC 02313 785 00200 VCID: 2446633AE77591628D-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 M Component: MNS ECE H50 1060 Revision: 00000000 Serial number: 364J-077721737 Shop #: WSC 00385 210 90050 VCID: 3B74B8467ACBCE9ADC-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H05 0090 Serial number: 00000726000015 Coding: 0232912 Shop #: WSC 02313 785 00200 VCID: 1D3056DEC41FA0AAC2-8048 1 Fault Found: 02138 - Control Circuit for Front Right Interior Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 239 Mileage: 110788 km Time Indication: 0 Date: 2016.12.21 Time: 01:53:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 F Component: T¸rsteuer.FS BRM005 0180 Coding: 0032623 Shop #: WSC 02313 785 00200 VCID: 204E6F2AF36D8D42E9-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 E HW: 4E0 907 289 E Component: Komfortgeraet H10 0010 Revision: 00100010 Serial number: W040710150060 Coding: 0004861 Shop #: WSC 02313 785 00200 VCID: 2B5488068AAB5E1A4C-807E Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P28H06 0100 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H05 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: None Part No SW: 4E0 910 466 D HW: 4E0 035 466 Component: BO_D3 H06 0320 Revision: 20S00002 Serial number: 02504070009182 Coding: 0000027 Shop #: WSC 02313 785 00200 VCID: 275C743696437A7AA8-8072 Subsystem 1 - Part No: 4E0 910 465 B Component: BO_D3_SLAVE H31 0310 Subsystem 2 - Serial number: 02407070006986 Subsystem 3 - Serial number: 0224.07.070000000100030024ˇ Subsystem 4 - Serial number: 030024ˇ No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 B Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000008403 Coding: 0010111 Shop #: WSC 02313 785 00200 VCID: 1E3251D2C919BBB2DB-804A Subsystem 1 - Part No: 8K0 907 410 Component: EHL205.06.02KHV H02 0010 Subsystem 2 - Serial number: 1451557T02TP01 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 F Component: T¸rsteuer.BF BRM005 0180 Coding: 0032623 Shop #: WSC 02313 785 00200 VCID: 204E6F2AF36D8D42E9-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000731 Shop #: WSC 56889 000 1048576 VCID: 204E6F2AF36D8D42E9-8074 1 Fault Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 5 Reset counter: 24 Time Indication: 0 Freeze Frame: Voltage: 5.38 V Count: 61 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 02313 785 00200 VCID: 2958720E80574C0ABE-807C Subsystem 1 - Part No: 4F0 941 329 D Component: AFS-Modul links H01 0010 Subsystem 2 - Part No: 4F0 941 329 D Component: AFS-Modul rechtsH01 0010 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 S Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 396J5077580768 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 31689A6EA88734CA76-8064 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 E HW: 4E0 919 148 Component: R0078 TVhybridT 0470 Revision: R0H06000 Serial number: 76300801312402 Coding: 0000003 Shop #: WSC 00579 210 91783 VCID: 25407E3EEC4F686A9A-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000013901 Shop #: WSC 00385 210 90050 VCID: 204E6F2AF36D8D42E9-8074 Subsystem 1 - Part No: 000 915 105 AK Component: von VA0 1308200306 Coding: 303030393135313035414B56413031333038323030333036 Shop #: WSC 13149 123 104857 1 Fault Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 255 Mileage: 110807 km Time Indication: 0 Date: 2016.12.22 Time: 15:36:20 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: T¸rsteuer.HL BRM005 0180 Coding: 0032623 Shop #: WSC 02313 785 00200 VCID: 1E3251D2C919BBB2DB-804A No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 A HW: 4F0 907 273 A Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000700054053 Coding: 0252329 Shop #: WSC 02313 785 00200 VCID: 204E6F2AF36D8D42E9-8074 No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H46 0630 Revision: 00000000 Serial number: 00000710010631 Shop #: WSC 12336 024 394758 VCID: 3662A97241E913F223-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 D Component: T¸rsteuer.HR BRM005 0180 Coding: 0032623 Shop #: WSC 02313 785 00200 VCID: 1E3251D2C919BBB2DB-804A 1 Fault Found: 02124 - Exterior Door Handle Switch 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 240 Mileage: 110800 km Time Indication: 0 Date: 2016.12.22 Time: 15:26:44 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08740727500405 Coding: 0301008 Shop #: WSC 02313 785 00200 VCID: 23446026E27B965AF4-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4F1-910-336.lbl Part No SW: 4F1 910 336 D HW: 4F1 862 335 Component: BTA H09 1120 Revision: 00H09000 Serial number: 00000007518615 Coding: 0060001 Shop #: WSC 02313 785 00200 VCID: 25407E3EEC4F686A9A-8070 No fault code found. End-------------------------(Elapsed Time: 03:32)-------------------------- |
#34
So my errors having been through and checked the VCDS fault lists, are:
02272 - Quiescent Current Stage 1 (can't find anything for this) 02124 - Exterior Door Handle Switch (ditto) 02596 - Rear Brake Pads Worn (they look like loads of flesh is left, I think Duffy didn't adapt when he put new ones on) 02138 - Control Circuit for Front Right Interior Lights (all lights work?) 00065 - Rear Left Footwell Heater (Z42) & (Z43) - both register different voltages in freeze frame 00003 - Control Module (talk about vague) 00668 - Supply Voltage Terminal 30 (?) Incidentally, the low battery warning is now showing on the car again, which is odd if its a new, fully charged battery! Last edited by 1781cc; 22nd December 2016 at 02:54 PM. |
#35
02272 - Quiescent Current Stage 1 Clear this and go for a drive so the Battery Monitor can settle down.
02124 - Exterior Door Handle Switch I would have expected a short to ground if it were water ingress. Does the external lock button work? 02596 - Rear Brake Pads Worn Do the rear pad adaptation procedure as per Ross Tech instructions 02138 - Control Circuit for Front Right Interior Lights Not sure 00065 - Rear Left Footwell Heater (Z42) & (Z43) - There's currently another thread about these 00003 - Control Module I'd leave this for now as messing with coding / basic setting could put the control head in Component Protection. This module is the main brain of the MMI 00668 - Supply Voltage Terminal 30 Related to the 02272 - Quiescent Current Stage 1 All fine in my opinion. Just clear and go for a drive so the Battery Monitor can settle down.
#36
Are all 4 interior lights working , are the map reading lights in the mirror working
Is the brake pad wear indicator light on ? The quiescent current could just be while you been testing it ...ignition being in doesn't half pull out all lot of amps ...battery volts soon drops Take for a good run like Matty says then go into battery regulation think group 6 and look at s o c ...state of charge ...should be up to 100'% after half hour run . My car had the code for exterior door handle .....it was the cause of my battery going low over night |
#37
First I would like to comment about old battery, the battery in pictures have warehouse picking slip label on it so it cannot be original battery from the factory as those labels are attached when dealer orders part from warehouse and would not be on factory battery.
As for the previous owner putting back old battery there are several possible scenarios. I am not going into much detail at this time but I am sure you can imagine most of them. In regards to electrician testing battery 12.1V seems very optimistic under load. How much load did he put on it? It's the kind of voltage you would see with engine off and lights on. Load testing should be at least 400A for this size of battery and even more. The voltage should be above 9.5V while cranking in most cases. My A6 drops to about 10.5V while glow plugs are on and to about 8.5V while cranking after preheat with a 4 years old battery which reports 60% health on conductance meter which recommends to replace battery. But overall there is more to battery testing, 3 main parameters are capacity, cold start amps and internal resistance. Cold start amps(load test) can be tested quickly but require specialist equipment and battery to be off car. There is no hand held load tester that can put 800A load on battery and dissipate heat and basic 100-200A load testers will not show true performance for batteries of this size. They are OK if you want to test you bike or 1.0 Corsa but will not tell much for big batteries. Capacity test is a bit long and would require draining battery with steady current over 20hrs, so for 100Ah battery you would put 5A load on it and measure the time it takes for voltage to drop belovw 11.9V or so. On a fresh battery it should be about 20hrs but if you get like half of that you can be sure it is duff. Conductance test does not give direct result in CCA or capacity but will give you a good idea in general battery condition and it is very quick. The new battery can also be duff if it has been sitting on the shelf too long and many of newer chemistry batteries require higher charging voltage, especially AGM batteries so if you fit advanced battery you might want to change voltage regulator on generator. I am happy to lend you my conductance tester if you want although it only goes for batteries up to 800CCA but still should give god indication. And finally I might be interested in you old battery if it is not too bad or too expensive.
#38
All is well with the world, the new battery has fixed my problems and the car starts on the button, quick scan and my errors have gone, no battery warning lights or anything.
I find it mental that a battery can cause so much havoc with the cars internal systems, it's just plain weird how it affected everything from internal lights to MMI, tyre pressure sensors and so on. Anyway, I wanted to wait a few days to make sure before saying thanks to all for your help in solving this, much appreciated! |
#39
Nice one! Mine did the same and all was sorted with a new battery!
CURRENT: 2006 Audi A8 D3 4.2 Tdi QS - CLICK HERE FOR PROJECT THREAD: Audi Exclusive Azure Blue, Amaretto brown interior, facelift rear lights, S8 mirrors, B&O, ACC, Digital TV, glass sunroof, Fridge, Extended Leather Pack 2, wooden steering wheel & gearknob, keyless entry, keyless start, electric boot, softclose doors SOLD : 2000 FL Silver D2 4.2 QS - Solar sunroof, Bose, Blinds, NavPlus, Playstation, DVD, wireless headphones, iPhone AV connection, RS6 steering wheel, chrome mirrors, phone prep, xenons, servotronic steering, Rear screen, TV-in-motion, NavPlus Alu rings, S8 exhaust, S8 bonnet grille, 385mm D3 S8 brakes, rubber winter mats, De-badged rear, US rear indicator clusters, 20" Final Edition diamond cut wheels, 15mm Eibach Pro spacers (front), 20mm H&R hubcentric spacers (rear). Audi A8/S8 D2 Flickr Group |
#40
Good to hear yours is sorted, I however, typed too soon...
Last night coming back from Milton Keynes, I was talking to the missus about how good to car has been this year with no issues aside from the battery, lo and behold, by the time I got the the A5 roundabout some 4 miles away, the lights on the dash flickered, the clock said 00:00 and the car wouldn't come out of 6th gear. I managed to get home (thank god for having a big v10 up front as 6th gear was still fine to pull away in) but she wouldn't change, either by putting her into tiptronic, paddles, Sport, Dynamic or via Neutral. Once home I put her into park, then the selector and everything worked fine, gear changes were ok again - took her for a spin and silky smooth once more. Turned her off, plugged her in, no gearbox errors or engine errors and the like, what caused that? have I got a duff battery? I went into the boot to check the terminals were attached correctly (they were) and noticed that the side of the battery appeared to be a little wet, yet everything around the battery, trim and the top of the battery was dry - what was that all about? Any ideas anyone? I have had no battery warning lights, but she has been slow to start on these really super cold mornings (-4 yesterday) |
