Replacing Your Broken Alarm Horn
Picked up a 2001 D2 FL a few months back and one of the niggles it had was it kept blowing one of the fuses, which also affected the interior lights. After some searching, the best possible cause was a failed alarm horn caused by leaking batteries. So I ventured, screwdriver in hand, to find the alarm and fix it. The following is how I went about it.
Remove the boot carpet by unscrewing the two plastic screws shown. The alarm horn is located behind the trim on the left side of the car, behind the CD autochanger. Remove the curved plastic trim at the side of the boot. There are two plastic lugs holding it in place. Pull the centre part of these out about halfway and then pull out both outer and inner parts. This piece of trim is also secured by what I can only describe as industrial strength velcro. It is very tough indeed, so care is needed when removing it. If possible, try and ease the trim away from the car using a thin piece of wood between the trim and the car. The next piece of trim to remove is along the back of the car. Here, you need to remove the two tie-down catches, two plastic lugs and the boot light. I think the two plastic lugs had covers (similar to others in the boot), but mine were missing. If you have them, just prise them off carefully, as they have a section that goes into the groove on the other lugs. Now remove the boot light. Use a flathead screwdriver and gently prise it out from the end. Remove both wires. Now remove the two tie-down catches using a Philips head screwdriver. Once removed, I tend to leave the screws in the catch for safekeeping. It's now time to remove the trim itself. This was the one I had the most issues with, as I didn't know what else was holding it in place. Start to prise it off from the left side of the car, as the right side will still be held in place by the corresponding curved piece of trim. You may also need to prise it up ever so slightly, as mine was catching on the plastic base of the boot. There are also four plastic clips holding the trim in place. Again, a thin piece of wood between plastic and metal for leverage is handy. Time now to remove the CD autochanger. There are four 10mm bolts holding it in place. The one at the back right is the most awkward one to remove unless you have a knuckle joint in your socket set. Once these are removed, carefully move the unit out and back to get access to the cable. You are almost rotating it about the front right bolt. To get better access, use needle nose pliers and squeeze the base of the plastic cable tie holding the cable in place. You should then be able to push it up out of the metal chassis. This will allow you to move the unit further into the boot area. Final piece of trim to remove before getting to the trim is the access cover for the lights. A simple 90 degree turn and out it comes. Strangely I didn't take a photo of the next stage, but what you now need to do is to gently pull the trim out from its position. You sort of have to take each piece of trim and draw them all together so that they don't catch on anything and then move it out and back, something like you do with the CD autochanger. The main thing is not to move it too far out as you may crease it. If you now look up into the top recess, you will see a small black box secured by a bolt. This is the alarm horn, and the culprit. Simply undo the bolt, raise the alarm up and then pull it gently back towards you. Note that the cable is very short, so it isn't going to move far. You should now be able to turn it around and unplug it from the loom. As you can see, the loom is very short indeed, and in my case even the plug has been corroded - so I can defintely say that the alarm is kaput. And if you're interested, this is what the inside of the alarm looked like when I pulled it apart. If you're lucky and the plug isn't corroded, you just need to get a replacement alarm. If it's like mine, then you either need to get a new plug (from where I don't know) as well. The alarm isn't specific to the A8, so others can be used, so long as they have the three pin plug. I was lucky to get one from a 05 A4, along with about a foot of the loom (BTW it's located in the lower right corner of the boot). Again, if you have to replace the plug, cut the cables as close to the plug as possible, as I took about ten minutes to splice the new one on. It was mostly done by feel. The obvious next stage before putting it all back together is to test that everything works. Close the boot and lock the car with the windows open. Wait for it to arm itself and then stick your arms into the car. With luck, the indicators will flash and you will get an annoying; but comforting; noise from the back of the car. Mine doesn't beep when I lock or unlock it, but I might need to use VCDS to sort that out. Reconstructing the boot is very simple. Just follow the same steps in reverse Place the new alarm in position and secure in place with the bolt. Move the trim back into position, again being careful not to crease any of it. You may need to fiddle with it to get all of it to line up. Replace the plastic light trim cover. Move the CD autochanger back towards its original position when you first moved it out. This allows you to secure the plastic cable tie in the autochanger chassis. I marked the hole where it should go. This is more awkward to do than removing it. Once done, rotate the autochanger back into position, being careful not to trap any cables at the back of it. Again, a bit of jiggling about may be required to seat it properly. Secure all four screws in position first by hand before tightening them down. The rear plastic trim now needs to be replaced. This is a fiddly bit, as you need to secure the right side into position with the curved right piece of trim. You also have to feed the two wires for the light through the relevant hole and then place the trim in position so that the four plastic clips are aligned to their respective holes. Holding the trim in place, start from the right side and push down on the trim above the plastic clips to secure them. You will feel them going into place. The next part is fitting the light while you still have a hold of the wires. I'm not sure about the wiring, so wired it exactly as I took it off, brown cable at the bottom. Feed the light into place, cables first, and then push in to secure. Secure both tie-down catches and then replace the two plastic lugs. Replacing the curved plastic trim is done by aligning it into the slot with the bottom trim piece and then pressing it to the velcro. Use the palm of your hand over the four areas marked and apply pressure and you will feel it snap into place. Then take the two plastic lugs and place them in the relevant holes, and then push the centre part all the way in. You may need to jiggle the back one, as you have to align the trim and the plastic to the hole. Finally, replace the CD cover and then secure the boot carpet with the two plastic screws. Addendum: Now that my alarm works, I wanted it to 'blip' when I locked the car. Came across a link to the following site 'Waks Wide Web', where it gives details on how to encode it with VCDS and a little downloadable program called BaseCode. I hope you find this guide useful.
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds Last edited by steamship; 8th October 2013 at 02:04 PM. |
This is extremely useful. Love these articles. Thank you so very much for it.
Do you have antenna on the boot? Based on your picture of where the recess is it seems that antenna is directly above it and what we see is water damage from poor antenna seal dripping directly on the unit. On picture of damaged plug I also see sound deadening material of what seems to be central locking pump. Are we sure there is no water ingress there?
I'd rather drive on left |
Agreed, great write up. Can we make it sticky please?
I also had problems with the aerial seal - but not on my current car (sorry David!) - and had to have the central locking pump replaced.
Thanks, great write up -
Added to the Interior Electrics Repair Sticky
Great write up, thanks for the contribution
For parts enquiries and Forum User Administration please contact customer services directly, not me - enquiry@a8parts.co.uk, www.a8parts.co.uk, or call 01642 783537 The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black , 2007 TT Roadster, 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
It's in the rear window think it uses the demist wires and is why the FL rear screen looks like it's come out of the 70's and the PF is almost completely clear.
>> I pulled the alarm apart, and it was definitely caused by
>> the two big button batteries leaking, which someone suggested. Thanks! I will open my box next time I get there and change those button batteries preventively.
My PF rear screen was equally riddled with wires as well as the "twirly" fixed aerial. But it did have the "full monty" of TV, LW/MW/FM radio, GSM and phone.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
The alarm horn is a sealed unit. Since mine was kaput, it didn't matter how I pulled it apart. It you plan on replacing the batteries, you're going to need something like a dremel to cut it apart where it was stuck together.
