Closed Thread
Old 21st January 2009, 06:00 PM
Default Interior Electrics Repair Sticky
Here we will post links to Interior Electrics related solutions. This post will be edited by an Administrator when a new solution is found either within this forum or elsewhere on the Interweb.
To Start the Ball Rolling here are some classic links from Paul W's Audipages. This site can't be recommended enough as a gold mine of information about you 8.
INTERIOR ELECTRICS
Airbag Warning Light - Passenger Seat - IT
ALARM - Bleeping from boot on start up - Battery Replacement.
ALARM PCB Repair due to failed horn
- daz.g
Replacing your broken alarm horn - steamship
Climate Control panel light replacement - Ska
Cruise Control Switch Replacement - Audipages
Cruise Control Switch Repair - entwisi
Fuse box fuse allocation - ainarssems
Immobilizer Wiring Replacement (Engine Cutting Out)
- Audipages
Immobilizer wire - additional information - RanjA8
Instrument Cluster Pin arrangements PF - PaulW on Audiworld
Instrument Cluster Pin arrangements Facelift - PaulW on Audiworld
Replacing a Faulty Rear PDC Sensor - IT
Wing Mirror ECU Replacement - General Git
How to - central locking pump removal and motor change - SilverS8
Retrofitting the rear blinds to a D2 - Steamship
Deflating Seat Bolster Repair. - Ronin
Remember, if you find a solution to a problem you've had or others have posted on the web let an Admin know (PM or email) and we will add it to this sticky.
Last edited by Conan_the_Librarian; 18th February 2021 at 05:57 PM. Reason: updated
Old 18th February 2021, 05:57 PM
Sticky Updated.
Closed Thread
