Fitting a Reversing Camera (and Digital TV)
Since my analogue TV tuner wasn't doing anything now, I decided to fit a reversing camera to the car, using the AV1 input on the TV tuner. The following is a guide on how I did it.
NOTE: This guide is based on having TV tuner B. Thanks to IT for identifying these in another post (http://forum.a8parts.co.uk/showthrea...ighlight=tuner). First thing to do is move the CD autochanger/TV tuner so that you can access it better. There are four 10mm bolts holding it in place. The one at the back right is the most awkward one to remove unless you have a knuckle joint in your socket set. Once these are removed, carefully move the unit out and back to get access to the cable. You are almost rotating it about the front right bolt. To get better access, use needle nose pliers and squeeze the base of the plastic cable tie holding the cable in place. You should then be able to push it up out of the metal chassis. This will allow you to move the unit further into the boot area. Looking directly at the back, you now need to release the large rectangular block connector. You can either cut the cable tie or using a fine screwdriver inserted at the front and undo it. You then need to move the white locking bracket to the right. As it does so, the connector will come out towards you. With the block connector removed, you have to separate the parts of the connector. To do this, you first need to prise the small black tabs away from the blue parts. I used very fine screwdrivers. At the other end of the connector, you now need to push the blue part out. This is a snug fit, so some pressure is needed. Now that the wiring is separated, you need to remove the blank blue section. This is done by just sliding it away from the wiring. We now have the new accessory cable to attach. I purchased mine off eBay (from here). The leads are 90cm long and consist of two sets of RCA connectors. The new loom is attached in the reverse of the above. First ensure that the ridge on the side of the new blue connector mates with the original connector. Then just slide the new one into place. So far it's been easy. Now comes probably the hardest part. You now need to feed the old and new loom back into the original black connector. Because of the two sets of RCA leads, this is a very tight fit. Just perservere until you hear the small black tabs click. Once done, you just need to connect it into the TV tuner. Set the connector in place and then move the white locking bracket from the right to the left, locking it in place. You can then secure it again with a cable tie. Now to fitting of the camera itself. Again, I purchased this from eBay (from here). As well as the camera, it comes with a power lead, video lead and hole saw. You will note the red wire attached to the video lead. This is the signal wire, but since the RNS-D never had an option for reversing camera, I doubt it would have an input for this signal wire. The next part is deciding where to place the reversing camera itself. I chose to put it just above the passenger side reversing light, similar to the way the boot button is located on the drivers side. ----- End of Part One -----
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds Last edited by steamship; 12th January 2014 at 04:16 PM. Reason: Removed reference to more photos |
To remove the light lense, remove the small bulb access flap. The bulbs are removed by turning them through 90 degrees and there is also another connector which just pulls off. The lense is held in place by four small bolts, three of which are easy to access. I chose to do it this way rather than removing the entire boot lid liner. Once the bolts have been removed, the lense will have to be pushed out. If it has never been out before, it will be very tight, just with the rubber seal around it being stuck to the metal.
Decide on where the centre of the camera will be, and then place a strip of masking tape or similar over it to protect it when drilling. Get it right and it looks like this: To get the wires from the camera, I just used the same holesaw and drilled a hole at the back of the lense unit near the top of the reversing light section, again covering it with masking tape before drilling (and covering when done to keep light in). Feed the wires from the camera through the front of the lense and then through the back. When fitting the camera into the hole, I only pushed it in halfway, so that I could first get the image straight on the screen. At this stage, you can refit the lense to the car, ensuring you don't push the camera all the way in. Once secured, the camera needs power. I just took the black and red lead (on the right of the picture of all the pieces) and put them through the hole in the spade connector for the reversing light. Once that was done, I just taped them to the reversing wires and reconnected all the bulbs. This only left the video lead to connect. To feed the lead up from the boot area, I removed three of the screws holding the boot lid liner in place. Using a flexible rod (blue in pic), I fed the cable up inside the boot. When the rod reaches the top, I just used some needle nose pliers to grab it and pull it out. The lead simply plugs into the power lead coming from the reversing light, and just needs taping and tucked out of sight. Now to test it. Closing the lid of the boot, I switched on the ignition, the RNS-D and selected AV1 input. I then put it in reverse and got an image, along with parking lines. Putting it in park, I then moved the camera and rechecked until I was happy that it was aligned properly. Once I was happy, I just gently pushed the camera all the way into the lense. Now I was happy with all that, I could screw down the boot lid liner and replace the bulb access cover. Since I had the CD changer cage out to fit the cabling, and the cabling provided two RCA inputs, I decided to fit a digital TV box as well. Using the wiring instructions from this 'post' and in particular post 17 (thanks to HPsauce and notorious), I wired in the power leads and then taped it all up. The TV box was again a cheap unit off 'eBay' and was placed using double sided tape to the top of the stack. The wire rising to the right is the video lead going to the camera. I fed the aerial and IR receiver in through the rear armrest, with the aerial sitting on the rear parcel shelf and the IR receiver and remote in the rear armrest until such time as I get around to taking the wiring to the front (weather, patience and other wiring jobs that need done - fog light switches and radio clock module already ones to do). I'm in a lousy location for digital TV reception, so had to test it when I was doing taxi service and waiting for someone and it worked fine. The only remaining thing left to do is to put the stack back in place and secure.
That's neat. I'm still playing around with mine, trying to install it in a 'hollow' boot lock. But this camera is nicer, with the 'grid lines', so I think I'll swap mine for one like this.
Because of curved line of the boot lid the rear lens is not exactly perpendicular to reversing direction. So camera doesn't look exactly rearwards if mounted flush with the lens. Deviation angle will be around 10 degrees. How is this compensated to achieve precise positionig of parking lines?
My camera was sold with a special ring that compensates that angle, but it doesn't have parking lines. It does have night vision LEDs though.
I'd rather drive on left Last edited by notorious; 14th January 2014 at 01:11 PM. |
Very neat. One thing though (and perhaps I missed something). You stated that the signal wire would not be used as RNS-D didnt have a reversing camera option but you later said that you engaged reverse and got a picture? I assumed that it was not going to be automatic but required you to select TV?
An excellent write up with very clear and detailed instructions.
Another one to add to the list and with the cost of the camera and tuner well worth the effort. Thanks Can one of the mods sticky this please if you haven't already. Ta
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again |
done!
Great write up mate
Joy to read Skill and perfection
A point of detail that I've been mulling, and isn't covered in the write-up, is routing of the video lead from boot lid to inside the body.
I can see where it would go initially (I've done similar before to solve GPS aerial issues) to get around the boot lid and even down one of the struts. But which strut is best, what is the entry point into the body and how is it sealed?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
