D2 - Lights Headlights, xenons, foglights. Everything outside the car that glows |
dipped headlights adjuster
just failed MOT !
have never used the adjuster on the dashboard , apparently this has to work [ have never used myself only one side works ...what and where is the actuater for this ...is this a commone fault ? |
Not sure what sort your headlights are, but here's an illustration showing the control motor (#12).
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
standard old fashioned bulbs so that is probably correct ...will have a look in the morning; probably fairly easily to get out
thanks |
well, I got out and got under and the problem is the circular dipped beam light which has a peculiar connector at the back , just a wire bracket or similar
any idea what exactly this is ? |
That just looks like the wiring to the bulb, the height adjustment will be elsewhere on the body of the reflector mounting.
Is it an H1 bulb, or similar? They just have a single blade connector, the return circuit being via the body/base which in your case goes to the yellow cable.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 23rd November 2019 at 04:43 PM. |
Just went out and checked mine, and it's the same. The following photo of mine shows the actuator in situ (highlighted in red). It is located inside the headlight unit in the corner closest to the radiator, behind the other back cover.
ok, so it is actually a ram.
question is , presuming I can get the correct part , how do I get to in to fit it ? looks like the back doesn't come off and if I can just remove the headlight how would that help? Last edited by oldnick; 24th November 2019 at 01:32 PM. |
Is it one of these? https://www.amazon.co.uk/Audi-Headli.../dp/B00NGZTNQI as sold by our sponsors!
(I'm sure they can advise on how to swap them over) I've never looked at a D2 for this, having had Xenons on both my S8s, but other cars I've had used very (extremely) similar units and they were quite easy to replace. Given the small number of companies actually making headlight units this isn't really surprising, it's probably a Hella, Bosch (or similar) standard part.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
thanks for that.....not actually that model but is actually one used on VW I find
a little research indicates that the reflector is detachable ....question is how to get the front glass off to do that , should be ok after that ! somebody must know how to remove the glass [ I hope !] |
As Andrew said, our sponsors may be the best guide to how they removed them (assuming the unit wasn't damaged at the front). It may be possible to use a screwdriver bit on a ring spanner to undo the screw, but it could be very fiddly. You will need to ensure you get the correct actuator for your headlight though. If you just have Halogen headlights, then the part number is 1J0941295A, but if you have the Xenon headlights, then the part number is 4B0941293A
