Go Back   A8 Parts Forum > General Natter > Owners Meets
Owners Meets Any info for any meetings, events, track days
Old 31st May 2023, 08:01 AM
Red face The Murple may not be there!
Following on from this thread, I did do Spa but it probably wasn't wise. Currently getting the AC de-gassed to fit a new pump but the work to identify the the air leak at the back of the engine necessitates the removal of the inlet manifold to access the underside. There is a possibility it's not a vacuum hose, but a corroded inlet manifold. I'm pulling my plugs to asses the degree of leaning out that's happened. Running the appropriate measuring blocks shows it's only happening a low revs/idle.
If I turn up in a Q3 please be gentle!
Old 31st May 2023, 12:31 PM
Sorry to hear that Mike. No matter what you turn up in, itll be good to see you both.
Old 31st May 2023, 12:48 PM
That'd be a shame, but it is what it is - hope you get it fixed. You can guarantee we'll be more gentle with you than with Sarg in his "no indicators" Beemer*
* crosses fingers, toes and everything else and hopes that Herman behaves, so I don't turn up in a Tesla
Old 31st May 2023, 05:47 PM
Turning up is the important part. I reckon you can handle any abuse thrown your way.
Old 31st May 2023, 08:15 PM
The abuse has already commenced
Good luck with sorting it, but I guess that driving a smaller motor will be punishment enough ... maybe.
