Thank you very much for the extensive reply Steamship!
I will work through all of your points and will update everyone in a week or two, I am already aware and are working on some items already. I sprayed contact cleaner into the plug for the wiper motor and it appears to have fixed the issue completely. Rear brake pads are on order (they are low but not enough to show on the dash yet, if these cars do that) An AMP was repaired by the garage just before I bought the car (something I noticed on test drive) so I will ask them which one and investigate, the tweeters are currently stuck in the up position, and they produce sound. They look very easy to remove so I'll leave that till last. I still haven't been able to replicate what happened on the way to Manchester, so I'll start by looking at the door handle and 02256 code!
Toby Current: 2007 S8 D3 5.2 V10 - Jap Import in Daytona Grey 2004 BMW X3 2.5i Manual (Old Workhorse) Previous: 2009 S5 4.2 V8 - Phantom Black with Red leather interior 2006 A4 3.0tdi Manual - Black with Black Leather 2001 BMW 323ci 2.5i Manual |
Thanks Steamship, been working on the car over the last few weeks and managed to clear a lot of the issues, brake pads, wiper motor, new air compressor and rear strut. However the strange electrical issue has returned, this time happening much more frequently. Here is the latest vag scan;
Code:
Saturday,16,September,2023,17:40:47:49881 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4 Data version: 20230421 DS346.2 www.Ross-Tech.com VIN: WAUZZZ4E87N026251 License Plate: V10 UWU Mileage: 98640km-61292mi Repair Order: Electrical Fault 1 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 11 31 13 15 16 17 19 1E 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 6C 72 76 VIN: WAUZZZ4E87N026251 Mileage: 98640km-61292miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels:. 07L-910-552-BSM1.clb Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI Ş0060 Revision: 5AH21--- Serial number: AUX3Z0G6727503 Coding: 01060003190F0260 Shop #: WSC 63314 001 1048576 VCID: 5F9BB094FB31B162561-800A VINID: 9D196AAAA115207780086085040FEAB896 2 Faults Found: 049717 - No Communications with Cruise Control (Front) Distance Sensor U0235 - 001 - - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 98385 km Time Indication: 0 Date: 2023.09.10 Time: 13:50:04 Freeze Frame: RPM: 650 /min Load: 26.3 % Speed: 2.0 km/h Temperature: 95.0°C Temperature: 21.0°C Absolute Pres.: 1010.0 mbar Voltage: 13.081 V 006435 - Please Check DTC Memory of ECU Number 2 P1923 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 98644 km Time Indication: 0 Date: 2023.09.15 Time: 03:53:06 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 69.0°C Temperature: 50.0°C Absolute Pres.: 1010.0 mbar Voltage: 11.557 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E2 910 156 C HW: 09E 927 156 B Component: AG6 09E 5,2 FSI RdW 0020 Revision: --H01--- Serial number: 0110368 Coding: 0000001 Shop #: WSC 02313 758 00200 VCID: 2411FF7892D7D2BA4B3-8070 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB Component: ESP 5.7 allrad H49 0500 Coding: 0001927 Shop #: WSC 02313 000 00000 VCID: 2411FF7892D7D2BA4B3-8070 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 907 181 C Component: FBS AUDID3 H12 0200 Revision: 02005112 Serial number: AUX3Z0G6727503 Coding: 0413184 Shop #: WSC 02311 785 00200 VCID: 58E99B889E1F465A17B-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 758 00200 VCID: 2411FF7892D7D2BA4B3-8070 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: None Part No SW: 4E0 910 769 N HW: 4E0 035 729 A Component: Interfacebox H43 1480 Revision: 00000000 Serial number: 347FQ077516035 Coding: 0000108 Shop #: WSC 11274 001 1048576 VCID: 372B38343341A922FE1-8062 Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0040 Subsystem 2 - Serial number: 00000000041979 Subsystem 3 - Serial number: 0103.07.070000000100010079˙ Subsystem 4 - Serial number: 010079˙ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000128413 Coding: 0123601 Shop #: WSC 02311 785 00200 VCID: 1C61C798AAA7EA7AF33-8048 2 Faults Found: 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 189 Mileage: 98616 km Time Indication: 0 Date: 2023.09.15 Time: 01:12:44 Freeze Frame: Voltage: 13.20 V 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 180 Mileage: 98325 km Time Indication: 0 Date: 2023.09.10 Time: 10:47:30 Freeze Frame: Voltage: 11.70 V ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.clb Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q Component: ILM Fahrer H15 0230 Coding: 0133001 Shop #: WSC 02313 758 00200 VCID: 36353530344B502AE57-8062 Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH13 0090 Coding: 00150573 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: None Part No SW: 4E0 910 121 HW: 4E0 035 121 Component: MD-Changer H42 0070 Revision: 00000001 Serial number: KE1059V7500190 Shop #: WSC 00000 000 00000 VCID: 57EB98B4930149221E1-8002 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels:. 07L-910-552-BSM2.clb Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI Ş0060 Revision: 5AH11--- Serial number: AUX3Z0G6727503 Coding: 01060003190F0260 Shop #: WSC 63314 001 1048576 VCID: 5F9BB094FB31B162561-800A 1 Fault Found: 049717 - No Communications with Cruise Control (Front) Distance Sensor U0235 - 001 - - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 98385 km Time Indication: 0 Date: 2023.09.10 Time: 13:50:04 Freeze Frame: RPM: 653 /min Load: 25.5 % Speed: 2.0 km/h Temperature: 95.0°C Temperature: 21.0°C Absolute Pres.: 1010.0 mbar Voltage: 13.208 V ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: 4E0-910-561.clb Part No SW: 4E0 910 561 F HW: 4E0 907 561 F Component: ABSTANDSREGELUNGH03 0020 Coding: 0041148 Shop #: WSC 02313 758 00200 VCID: 2517E27C99ED2BB25CD-8070 4 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 013 - Check DTC Memory - Intermittent - MIL ON Freeze Frame: Fault Status: 10111101 Fault Priority: 5 Fault Frequency: 4 Reset counter: 229 Mileage: 98408 km Time Indication: 0 Date: 2023.09.10 Time: 04:37:00 Freeze Frame: Temperature: 32.0°C Voltage: 13.70 V Bin. Bits: 00100000 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent - MIL ON Freeze Frame: Fault Status: 10111101 Fault Priority: 5 Fault Frequency: 5 Reset counter: 229 Mileage: 98408 km Time Indication: 0 Date: 2023.09.10 Time: 04:37:00 Freeze Frame: Temperature: 32.0°C Voltage: 11.65 V Bin. Bits: 00100000 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10110010 Fault Priority: 5 Fault Frequency: 1 Reset counter: 221 Mileage: 98384 km Time Indication: 0 Date: 2023.09.10 Time: 13:50:00 Freeze Frame: Temperature: 35.0°C Voltage: 8.58 V Bin. Bits: 00100000 01315 - Transmission Control Module 013 - Check DTC Memory - Intermittent - MIL ON Freeze Frame: Fault Status: 10111101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 229 Time Indication: 0 Freeze Frame: Temperature: 27.0°C Voltage: 12.42 V Bin. Bits: 11100000 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H14 4210 Revision: 91H14421 Serial number: 0037P0G0FS5D Coding: 0430707 Shop #: WSC 02313 758 00200 VCID: 270BE874E3E139A26E1-8072 Subsystem 1 - Serial number: 63328RB402B9EE23X Subsystem 2 - Serial number: 63428RB402B9F085T Subsystem 3 - Serial number: 63528RB402B9EFE24 Subsystem 4 - Serial number: 63628RB402B9F0DB% Subsystem 5 - Serial number: 63729RB402915BC5S Subsystem 6 - Serial number: 63829RB402915BF1S No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 A HW: 4E0 953 549 C Component: J0527 0410 Revision: 00H04000 Serial number: 90025071860086 Coding: 0112151 Shop #: WSC 02311 785 00200 VCID: 2615E570E4EB20AA557-8072 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H02 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 931 N HW: 4E0 920 931 N Component: KOMBIINSTR. VDO H82 0530 Revision: D05 Serial number: AUDID3G6001400 Coding: 0048913 Shop #: WSC 33268 002 1048576 VCID: 2E051D50CC1B68EAAD7-807A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4L0-910-468.clb Part No SW: 4L0 910 468 HW: 4E0 907 468 G Component: J533__Gateway H06 0040 Revision: 00H06000 Serial number: 0100J077138055 Coding: F5F5DFFF71260E Shop #: WSC 02313 758 00200 VCID: 6C81D7583A87DAFAC33-8038 1 Fault Found: 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 4 Reset counter: 206 Mileage: 97773 km Time Indication: 0 Date: 2023.08.22 Time: 10:12:38 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 B HW: 4E0 035 110 Component: MP3-Changer H46 0350 Revision: 00046004 Serial number: AUZ5ZBG2030766 Shop #: WSC 00000 000 00000 VCID: 176BD8B453818922DE1-8042 No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 D Component: KLIMA-STG. FOND 017 0230 Revision: 00000020 Serial number: 00000000057436 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 619FB66CCD458792605-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.clb Part No SW: 4E0 910 553 L HW: 4E0 907 553 H Component: LUFTFDR.-CDC H07 6340 Coding: 0015510 Shop #: WSC 56676 001 1048576 VCID: 2C011758FA071AFA833-8078 3 Faults Found: 01583 - Leak in System Detected 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 18 Reset counter: 229 Mileage: 98332 km Time Indication: 0 Date: 2023.09.10 Time: 12:08:26 01400 - Suspension Level Control 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 2 Reset counter: 224 Mileage: 98325 km Time Indication: 0 Date: 2023.09.10 Time: 11:58:03 01577 - Turn-Off due to Over-Temp 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 4 Fault Frequency: 11 Reset counter: 229 Mileage: 98336 km Time Indication: 0 Date: 2023.09.10 Time: 12:17:18 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063338 Shop #: WSC 02313 758 00200 VCID: 2411FF7892D7D2BA4B3-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 K HW: 4E0 919 887 B Component: MNS JP H04 0590 Revision: 0000005S Serial number: AUZBZ7G0105064 Shop #: WSC 02313 758 00200 VCID: 36353530344B502AE57-8062 Subsystem 1 - Part No: 4E1 910 336 Component: Interface Handy H08 0050 1 Fault Found: 02288 - Control Module for Chip Card Reader (J676) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 43 Mileage: 94503 km Time Indication: 0 Date: 2023.05.06 Time: 15:28:58 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H05 0090 Serial number: 00000718400012 Coding: 0036006 Shop #: WSC 64595 001 1048576 VCID: 1D67CA9CB1BDE37204D-8048 3 Faults Found: 00211 - Control Circuit for Rear Illumination Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 4 Reset counter: 190 Mileage: 98640 km Time Indication: 0 Date: 2022.09.15 Time: 00:18:00 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 221 Mileage: 98340 km Time Indication: 0 Date: 2022.09.10 Time: 13:04:00 00308 - Supply Voltage for Motors for Sunroof/sunroof Shade 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 229 Mileage: 98640 km Time Indication: 0 Date: 2022.09.15 Time: 00:29:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 D Component: Türsteuer.FS BRM005 0180 Coding: 0032750 Shop #: WSC 02313 785 00200 VCID: 2019F36886CFCE9A2FB-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 D HW: 4E0 907 289 D Component: Komfortgeraet H08 0020 Revision: 00200008 Serial number: W040707310094 Coding: 0004840 Shop #: WSC 02313 758 00200 VCID: 2A0D1140F0F304CA71F-807E Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P27H08 0090 2 Faults Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 190 Mileage: 90046 km Time Indication: 0 Date: 2022.01.15 Time: 10:30:14 01134 - Alarm Horn (H12) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 190 Mileage: 90046 km Time Indication: 0 Date: 2022.01.15 Time: 10:30:14 ------------------------------------------------------------------------------- Address 47: Sound System Labels: None Part No SW: 4E0 910 466 B HW: 4E0 035 466 Component: BO_D3 H06 0180 Revision: 20S00002 Serial number: 01903070008472 Coding: 0000017 Shop #: WSC 02313 758 00200 VCID: 2517E27C99ED2BB25CD-8070 Subsystem 1 - Part No: 4L0 910 465 A Component: BO_D3_SLAVE H41 0780 Subsystem 2 - Serial number: 01304120020030 Subsystem 3 - Serial number: 0213.04.120000000100010030˙ Subsystem 4 - Serial number: 010030˙ 3 Faults Found: 03016 - Motor for Front Right Treble Speaker (V345) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 85 Reset counter: 190 Mileage: 98325 km Time Indication: 0 Date: 2023.09.10 Time: 10:51:18 Freeze Frame: Voltage: 12.00 V Temperature: 29.0°C Bin. Bits: 00000100 Voltage: 12.00 V Temperature: 34.0°C 03017 - Motor for Left Front Treble Speaker (V344) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 85 Reset counter: 190 Mileage: 98325 km Time Indication: 0 Date: 2023.09.10 Time: 10:51:18 Freeze Frame: Voltage: 12.00 V Temperature: 29.0°C Bin. Bits: 00000100 Voltage: 12.00 V Temperature: 34.0°C 03000 - Amplifier for Digital Sound Package (R184) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 83 Reset counter: 190 Mileage: 98325 km Time Indication: 0 Date: 2023.09.10 Time: 11:55:56 Freeze Frame: Voltage: 11.70 V Temperature: 26.0°C Bin. Bits: 00000100 Voltage: 11.50 V Temperature: 27.0°C Bin. Bits: 00000010 Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 B Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000008261 Coding: 0010101 Shop #: WSC 02313 758 00200 VCID: 1E65CD90BCBBF86A1D7-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 D Component: Türsteuer.BF BRM005 0180 Coding: 0032750 Shop #: WSC 02313 785 00200 VCID: 2019F36886CFCE9A2FB-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000733 Shop #: WSC 09308 002 1048576 VCID: 2019F36886CFCE9A2FB-8074 5 Faults Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 2 Reset counter: 229 Time Indication: 0 Freeze Frame: Voltage: 11.90 V Count: 247 00576 - Terminal 15 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 4 Fault Frequency: 2 Reset counter: 229 Time Indication: 0 Freeze Frame: Voltage: 11.90 V Count: 41 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 189 Mileage: 98616 km Time Indication: 0 Date: 2023.09.15 Time: 01:12:15 Freeze Frame: Voltage: 9.52 V Count: 61 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 226 Mileage: 98536 km Time Indication: 0 Date: 2023.09.12 Time: 16:38:06 Freeze Frame: Voltage: 13.35 V Count: 236 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 229 Time Indication: 0 Freeze Frame: Voltage: 11.90 V Count: 246 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 02313 785 00200 VCID: 290FEE4CF5F50FD2785-807C Subsystem 1 - Part No: 4F0 941 329 D Component: AFS-Modul links H01 0010 Subsystem 2 - Part No: 4F0 941 329 D Component: AFS-Modul rechtsH01 0010 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 N HW: 4E0 035 541 R Component: TUNER Japan H42 0180 Revision: 00000000 Serial number: 325GN077535052 Coding: 0000003 Shop #: WSC 02313 758 00200 VCID: 2B031444FF091DC28A9-807E 3 Faults Found: 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 2 Reset counter: 226 Mileage: 97209 km Time Indication: 0 Date: 2023.08.13 Time: 09:44:27 00447 - Function Limitation due to Over-Voltage 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 254 Reset counter: 226 Mileage: 0 km Time Indication: 0 00856 - Radio Antenna 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 43 Reset counter: 190 Mileage: 91968 km Time Indication: 0 Date: 2023.03.10 Time: 13:25:35 ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 F HW: 4E0 919 146 C Component: TV analog TUNER H15 0290 Revision: 00000076 Serial number: 00000000015579 Coding: 0000016 Shop #: WSC 02313 785 00200 VCID: 2411FF7892D7D2BA4B3-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000010459 Shop #: WSC 63314 001 1048576 VCID: 2019F36886CFCE9A2FB-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 341126Q0W1 Coding: 344530393135313035412056413033343131323651305731 Shop #: WSC 65372 001 1048576 5 Faults Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 255 Mileage: 98386 km Time Indication: 0 Date: 2023.09.10 Time: 00:02:55 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 98386 km Time Indication: 0 Date: 2023.09.10 Time: 00:09:52 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 98386 km Time Indication: 0 Date: 2023.09.10 Time: 00:10:03 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 98386 km Time Indication: 0 Date: 2023.09.10 Time: 00:10:13 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 98386 km Time Indication: 0 Date: 2023.09.10 Time: 00:10:23 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: Türsteuer.HL BRM005 0180 Coding: 0032750 Shop #: WSC 02313 785 00200 VCID: 1E65CD90BCBBF86A1D7-804A No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 A HW: 4F0 907 273 A Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000600058977 Coding: 0222428 Shop #: WSC 11918 001 1048576 VCID: 2019F36886CFCE9A2FB-8074 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4E0-910-441.clb Part No SW: 4E0 910 441 HW: 4L0 907 441 A Component: J772__Rearview 0050 Revision: --H12--- Serial number: 525PA8-J77109R Coding: 1121402 Shop #: WSC 02313 758 00200 VCID: 5CE18798EA27AA7A333-8008 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Cannot be reached ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08730720812861 Coding: 0221008 Shop #: WSC 02313 758 00200 VCID: 2313FC6497D9D582329-8076 No fault code found. End----(Elapsed Time: 02:39, VBatt start/end: 11.5V/11.6V. VIgn 11.6V)----- Everything seems to point towards a similar code "Function Limitation due to Under-Voltage" I have tested the battery and alternator myself and at two different garages and they both said there's nothing wrong there. I've checked as many fuses as I can find, I can't seem to locate this strange issue.
Address 01: 049717 - 13:50 on 10/09/23
Address 03: 01826 Address 11: 049717 - 13:50 on 10/09/23 Address 13: 01317/01316 - 04:37 on 10/09/23 Address 13: 00446 - 13:50 on 10/09/23 Address 19: 00384 - 10:12 on 22/08/23 - try reseating fibre connectors Address 34: 01400/01583/01577 - 12:08 on 10/09/23 - was this prior to replacement of the compressor and strut? Address 37: 02288 - was in last scan. Did it not clear? This has to do with the Japan nav system. Wondering if it's coded for it, but disconnected. Address 38: 00211 - was in last scan, but date has changed from 30/04/22 to 15/09/22. Very odd. Address 53: 00456/00576/01316/01299 - 15/09/23 - all voltage related Address 56: 00532/00447 - both over voltage related Address 61: All from 10/09/23 Just noted down what I spotted from your latest scan, and there is a lot relating to voltage, some due to a battery disconnect, but others not so. The voltages in Address 13 are all over the place (maybe the values are correct for the relevant part), and those are causing the errors in Address 01 and Address 11. Do you know if there has been or is any water ingress into the cabin? Wondering about water/damp around the roof electronics and behind the glovebox where the CAN gateway is. Would also check the boot area around and above the battery. Unfortunately there's nothing I can spot either from this or the previous scans that can pinpoint what the root cause is here.
Thanks both,
No obvious water ingress, I did check quite extensively whilst waiting for parts fitting the air compressor, I checked all drain holes etc, even with the rain we've been having, no damp carpets.... Good point on the voltages, I will check more thoroughly with voltages at the fuses, and I've also been advised to check J644 - Energy management control unit.
I did some searching and couldn't find anything about voltage spikes in the D3, but came across one for the D2 where they said a voltage spike threw the transmission into limp mode. Just wondering if that was the 'jerked/jumped' situation you experienced. Unfortunately there was never an update to the thread, as to their final solution: https://forums.quattroworld.com/a8/threads/8526.phtml
Hi All,
Quick update, we took out the battery, cleaned all of the connections and applied terminal grease to the connections as some were dirty, put everything back and made sure everything was tight and the issue appears to have gone away, I'm yet to do a long 1hr plus trip, but it seems to have fixed the issue! Thanks all
Do I risk hijacking this thread?
![]() Looking through the first scan above I saw a lot of errors the same as what I'm getting with my scan today, with modules I've never had issue with. The scan stemmed from me coming out this morning and the car appearing dead as a dodo and not responding to the remote whatsoever. I didn't have time to investigate further but when I got home later I tried my other remote with the same result. I thought I'd maybe left the car unlocked overnight and the battery was flat but on testing it was 12.4 volts so I used the key to open the driver door and as I turned the key I immediately saw the handle light illuminate so all in order there. I sat into the car with the key and it started on the button without issue. I subsequently got out of the car and locked it successfully with the remote. I did a scan which I didn't save where about 90% of the modules were throwing errors mostly voltage issues with the wiping motor, horn and parking brake standing out to me for some reason. I thought maybe I had gotten water into the CCM or something with all the recent heavy rain, and subsequently I'm getting intermittent key not recognised errors only to work 5 minutes later, so there's definitely something amiss. I've cleared the DTCs and going for a drive and seeing what I have when I return.
Phantom Black 2008 A8 3.0 TDI SE ASB |
Had a few more instances of the key fob not being detected when locking/unlocking the car and several scans similar to the below errors but with a Navigation defective media error also. I removed the disc and it read OK in my PC but haven't put it back in before doing the scan below. I've only listed the modules with errors and the only non-usual errors listed are Parking Brake and Alarm Horn. I haven't done a physical investigation yet but the rear discs and pads were only done 7k miles ago. The horn error has me baffled also, as car has no problem chirping when locking. Can someone tell me or point me to a photo of where the drain holes are in the plenum area under the scuttle panel?
Code:
Address 01: Engine Labels: 059-907-401-ASB.clb Part No SW: 4E0 910 402 E HW: 4E0 907 401 D Component: 3.0L V6TDI G000AG 0020 Revision: --H05--- Serial number: AUX3Z0H1342405 Coding: 0011973 Shop #: WSC 02313 785 00200 VCID: 1E65DD6D3CB162BA1D7-804A VINID: 9D196AAAA115188780042000249DC8F77E 2 Faults Found: 012597 - Intake Manifold Runner Control P3135 - 001 - Lower Stop not Reached Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 12 Reset counter: 255 Mileage: 238011 km Time Indication: 0 Date: 2023.09.21 Time: 18:54:14 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 11.70 V Duty Cycle: 88.8 % Duty Cycle: 88.8 % Duty Cycle: 20.5 % 004120 - Intake Manifold Runner (Bank 2) P1018 - 001 - Lower limit not reached Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 11 Reset counter: 255 Mileage: 238011 km Time Indication: 0 Date: 2023.09.21 Time: 18:54:14 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 11.70 V Duty Cycle: 88.8 % Duty Cycle: 88.8 % Duty Cycle: 20.5 % Readiness: 1 2 0 0 0 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000142589 Coding: 0018449 Shop #: WSC 02311 785 00200 VCID: 1C61D7652AAD70AAF33-8048 2 Faults Found: 00065 - Rear Left Footwell Heater (Z42) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 172 Mileage: 238011 km Time Indication: 0 Date: 2023.09.21 Time: 18:54:43 Freeze Frame: Voltage: 11.70 V 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 5 Reset counter: 172 Mileage: 238011 km Time Indication: 0 Date: 2023.09.21 Time: 18:54:43 Freeze Frame: Voltage: 11.70 V ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 F Component: Türsteuer.FS BRM005 0180 Coding: 0028462 Shop #: WSC 02313 785 00200 VCID: 2019E39506C5544A2FB-8074 1 Fault Found: 02124 - Exterior Door Handle Switch 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 172 Mileage: 238000 km Time Indication: 0 Date: 2023.09.21 Time: 18:55:50 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 E HW: 4E0 907 289 E Component: Komfortgeraet H10 0030 Revision: 00300010 Serial number: W040802050195 Coding: 0005341 Shop #: WSC 02313 785 00200 VCID: 2B0304B97F0387128A9-807E Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H05 0020 1 Fault Found: 01134 - Alarm Horn (H12) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 82 Reset counter: 176 Mileage: 237462 km Time Indication: 0 Date: 2023.02.24 Time: 19:50:00 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000221 Shop #: WSC 12345 111 45725 VCID: 2019E39506C5544A2FB-8074 1 Fault Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 152 Time Indication: 0 Freeze Frame: Voltage: 9.83 V Count: 61 End----------(Elapsed Time: 02:06, VBatt start/end: 13.9V/13.8V)-----------
00065/00066 - Common fault. The 'heaters' are nothing more than a bank of transistors attached to a bank of heatsinks and encased in an epoxy, and they burn out after time. This is what they look like inside: 01134 - Tends to mean that the battery inside the unit is starting to corrode, and you'll eventually be getting the alarm going off by itself for no apparent reason. If you don't already know, the alarm is situated in the plenum chamber on the passenger side, in the very far corner. 02596 - Never experienced this, but since the pads are reasonably new, then the likely cause is the adaptation was either never done or the wrong value entered when the pads were fitted.
