Old 8th December 2023, 11:23 PM
Default Forum not crashing
Its been a while, and for that I apologise.
The forum used to go offline every once in a while, then a bit more often, then it became unbearable.
The underlying issue was almost certainly to do with the underlying mysql database, but as luck wouldn't have it, it would always die at the most inconvenient times, meaning we could either (a) leave it down till i have time or (b) just reboot it
In the background i had already been doing a lot of work to transition the whole forum, as is, across to a new O/S, new server, new DB, new web server etc.
I expedited this and 23 days ago it was migrated and it has been up and running perfectly, for 23 days. All signs are that it will simply stay up and running.
We have also enforced HTTPS.
The edit button will be back, its taken a vacation for reasons I won't go into right now, but it will be back.
Now I've upgraded all the underlying bits, moving up to Vbulletin 4 and 5 should be significantly easier, so maybe we'll look into getting that done over the holiday period.
Thanks all for your patience
Old 9th December 2023, 07:01 AM
Thanks for your work Ian. I seldom post as the D3 chat is quiet these days, but do check in almost daily.
Matt
Old 9th December 2023, 08:08 AM
HPsauce HPsauce is online now
Well done Ian, the stability is most welcome. Anything else can wait its turn.
Old 9th December 2023, 09:35 AM
Default Thanks.
Nice one Ian. We're all lucky to have such a rich resource and source of advice running for free, and it's greatly appreciated
Old 9th December 2023, 11:37 AM
Glad that you've got things sorted, as it's a wealth of information that could have become NLA.
Sounds juicy! Ah, go on, spill the nerdy beans.
Old 9th December 2023, 03:41 PM
Thanks from me too, Ian. Your work is much appreciated
Old 9th December 2023, 06:07 PM
BZ as we say in the RN. Your work is appreciated.
Old 10th December 2023, 10:13 PM
Much appreciated, thank you Ian
Old 14th December 2023, 09:45 AM
Plus one from me
Old 14th December 2023, 05:40 PM
Saff Saff is offline
+1 for me
2010 D4 SE Executive 4.2 TDI
