Old 30th January 2011, 09:57 AM
Oli18's Avatar
Oli18 Oli18 is offline
Default Vagcom question about abs sensors
Hi,
If you've had an ABS & traction control light come on on the dash, do you need to clear it through vagcom if you (think) you have fixed the issue?
Or should it automatically turn of if the issue is fixed?
I have just put in the newer ABS sensors but my dash lights are still on without access to vagcom and am not sure if my issue is fixed...
Oli
Audi A8/S8 D2 Flickr Group
Old 30th January 2011, 10:18 AM
I think fault lights are only lit if a fault exits. If the fault is cured/goes away the light goes out and the record of the fault is kept in the appropriate module/ecu etc to be read by VCDS or other diag tool.
Old 30th January 2011, 11:05 AM
ABS ones go away as I had it on my D2 with a dodgy cable. You may need to re-check your pin connections..
Old 30th January 2011, 02:08 PM
Oli18's Avatar
Thanks chaps...all sorted.
For some reason it took a little drive to clear it but it's all sorted now
Oli
