Old 22nd December 2016, 10:14 AM
1781cc 1781cc is offline
Thanks guys, will get out there in a sec and report back!
Old 22nd December 2016, 10:20 AM
You done it yet
Remember to go to each module one by one after full scan and clear faults individually.
Sometimes you've got to jump ahead a bit, if there is fault in ABS ECU reported in engine's ECU you will have to clear ABS faults first and then go back to engine's ECU to clear the message and ABS faults.
You still doing it?? What takes you so long
Old 22nd December 2016, 02:40 PM
OK, got VCDS to accept new coding for the battery - sorted
Cleared all the codes manually after doing a full scan while running, locked and left the car, went back and there is this little lot:
Friday,23,December,2016,00:43:59:44654
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ4E78N003545 License Plate:
Mileage: 110800km-68847mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 1D 1E 28 34
36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77
VIN: WAUZZZ4E78N003545 Mileage: 110800km-68847miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 4E0 910 552 G HW: 4E0 907 552
Component: 5.2L V10/4V FSI ™0020
Revision: 5AH15--- Serial number: AUX3Z0G9332471
Coding: 01060003190F0160
Shop #: WSC 02313 785 00200
VCID: 264279329149637293-8072
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E2 910 156 C HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI RdW 0030
Revision: --H04--- Serial number: 0113762
Coding: 0000001
VCID: 2446633AE77591628D-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 K HW: 4E0 614 517 BT
Component: ESP 5.7 allrad H49 0650
Coding: 0001627
Shop #: WSC 02313 000 00000
VCID: 2B5488068AAB5E1A4C-807E
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0G9332471
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58BE07CAEBBD0582D1-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 0
Reset counter: 25
Mileage: 110800 km
Time Indication: 0
Date: 2016.12.22
Time: 15:35:58
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300JT077588153
Coding: 0000002
VCID: 3A7ABD4275F1F792C7-806E
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000047342
Subsystem 3 - Serial number: 0108.10.070000000100010149ˇ
Subsystem 4 - Serial number: 010149ˇ
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 240
Mileage: 110807 km
Time Indication: 0
Date: 2016.12.22
Time: 15:29:54
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000132966
Coding: 0123001
VCID: 1C365BDADF05A9A235-8048
2 Faults Found:
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 240
Mileage: 110788 km
Time Indication: 0
Date: 2016.12.21
Time: 01:45:37
Freeze Frame:
Voltage: 12.00 V
00065 - Rear Left Footwell Heater (Z42)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 239
Mileage: 110788 km
Time Indication: 0
Date: 2016.12.21
Time: 02:00:00
Freeze Frame:
Voltage: 14.30 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E2 955 113 C
Component: ILM Fahrer H16 0240
Coding: 0133121
VCID: 387EA74A4BFDE58231-806C
Subsystem 1 - Part No: 4E2 910 113 C
Component: Wischer WWS D3 H60 0440
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0002
Coding: 00141886
Shop #: WSC 02313
Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H20 0850
Revision: 00000000
Coding: 010000
Shop #: WSC 00481 210 83110
VCID: 2B5488064AAB5E1A4C-807E
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276V7600354
Coding: 0000001
Address 11: Engine II Labels: Redir Fail!
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 E HW: 4E0 959 655 K
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CU000228E
Coding: 0431707
VCID: 285E770A9B5D7502A1-807C
Subsystem 1 - Serial number: 63328RB402F082A1G
Subsystem 2 - Serial number: 63428RB402F08303A
Subsystem 3 - Serial number: 63528RB402F08308G
Subsystem 4 - Serial number: 63628RB402F082A8Q
Subsystem 5 - Serial number: 63729RB402A9C855Y
Subsystem 6 - Serial number: 63829RB402A9C84D%
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0410
Revision: 00H05000 Serial number: 90054072580024
Coding: 0112141
Component: E0221 H02 0100
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 M HW: 4E0 920 951 M
Component: KOMBIINSTR. VDO H83 0620
Revision: D03 Serial number: AUDID3G9000135
Coding: 0048423
Shop #: WSC 60756 001 1048576
VCID: 2F6C9C16BEB3223A60-807A
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B07A0183FF
Coding: F5F59FFF707E1E00
VCID: 2D50861EB4BF502A52-8078
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 A HW: 4E2 905 218 B
Component: FPI_1 H01 0020
Revision: 01000102 Serial number: 10102007110845
Shop #: WSC 00000 000 00000
VCID: 1F4C6CD6CE13B2BAD0-804A
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046006 Serial number: AUZ5ZBG3498338
VCID: 1A3A5DC2D531D79227-804E
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000060119
Coding: 0000000
VCID: 61C82A2EB8E7C44AA6-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 L HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 6340
Coding: 0015510
VCID: 2C568B1A8FA5592245-8078
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063342
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H50 1060
Revision: 00000000 Serial number: 364J-077721737
Shop #: WSC 00385 210 90050
VCID: 3B74B8467ACBCE9ADC-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000726000015
Coding: 0232912
VCID: 1D3056DEC41FA0AAC2-8048
1 Fault Found:
02138 - Control Circuit for Front Right Interior Lights
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 239
Mileage: 110788 km
Time Indication: 0
Date: 2016.12.21
Time: 01:53:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 F
Component: T¸rsteuer.FS BRM005 0180
Coding: 0032623
VCID: 204E6F2AF36D8D42E9-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0010
Revision: 00100010 Serial number: W040710150060
Coding: 0004861
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P28H06 0100
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 D HW: 4E0 035 466
Component: BO_D3 H06 0320
Revision: 20S00002 Serial number: 02504070009182
Coding: 0000027
VCID: 275C743696437A7AA8-8072
Subsystem 1 - Part No: 4E0 910 465 B
Component: BO_D3_SLAVE H31 0310
Subsystem 2 - Serial number: 02407070006986
Subsystem 3 - Serial number: 0224.07.070000000100030024ˇ
Subsystem 4 - Serial number: 030024ˇ
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000008403
Coding: 0010111
VCID: 1E3251D2C919BBB2DB-804A
Subsystem 1 - Part No: 8K0 907 410
Component: EHL205.06.02KHV H02 0010
Subsystem 2 - Serial number: 1451557T02TP01
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 F
Component: T¸rsteuer.BF BRM005 0180
Coding: 0032623
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000731
Shop #: WSC 56889 000 1048576
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 5
Reset counter: 24
Time Indication: 0
Freeze Frame:
Voltage: 5.38 V
Count: 61
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000018
VCID: 2958720E80574C0ABE-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396J5077580768
Coding: 0000001
VCID: 31689A6EA88734CA76-8064
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 E HW: 4E0 919 148
Component: R0078 TVhybridT 0470
Revision: R0H06000 Serial number: 76300801312402
Coding: 0000003
Shop #: WSC 00579 210 91783
VCID: 25407E3EEC4F686A9A-8070
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000013901
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1308200306
Coding: 303030393135313035414B56413031333038323030333036
Shop #: WSC 13149 123 104857
1 Fault Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 110807 km
Time Indication: 0
Date: 2016.12.22
Time: 15:36:20
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: T¸rsteuer.HL BRM005 0180
Coding: 0032623
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000700054053
Coding: 0252329
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H46 0630
Revision: 00000000 Serial number: 00000710010631
Shop #: WSC 12336 024 394758
VCID: 3662A97241E913F223-8062
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: T¸rsteuer.HR BRM005 0180
Coding: 0032623
1 Fault Found:
02124 - Exterior Door Handle Switch
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 240
Mileage: 110800 km
Time Indication: 0
Date: 2016.12.22
Time: 15:26:44
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08740727500405
Coding: 0301008
VCID: 23446026E27B965AF4-8076
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 D HW: 4F1 862 335
Component: BTA H09 1120
Revision: 00H09000 Serial number: 00000007518615
Coding: 0060001
End-------------------------(Elapsed Time: 03:32)--------------------------
Old 22nd December 2016, 02:51 PM
So my errors having been through and checked the VCDS fault lists, are:
02272 - Quiescent Current Stage 1 (can't find anything for this)
02124 - Exterior Door Handle Switch (ditto)
02596 - Rear Brake Pads Worn (they look like loads of flesh is left, I think Duffy didn't adapt when he put new ones on)
02138 - Control Circuit for Front Right Interior Lights (all lights work?)
00065 - Rear Left Footwell Heater (Z42) & (Z43) - both register different voltages in freeze frame
00003 - Control Module (talk about vague)
00668 - Supply Voltage Terminal 30 (?)
Incidentally, the low battery warning is now showing on the car again, which is odd if its a new, fully charged battery!
Old 22nd December 2016, 03:31 PM
02272 - Quiescent Current Stage 1 Clear this and go for a drive so the Battery Monitor can settle down.
02124 - Exterior Door Handle Switch I would have expected a short to ground if it were water ingress. Does the external lock button work?
02596 - Rear Brake Pads Worn Do the rear pad adaptation procedure as per Ross Tech instructions
02138 - Control Circuit for Front Right Interior Lights Not sure
00065 - Rear Left Footwell Heater (Z42) & (Z43) - There's currently another thread about these
00003 - Control Module I'd leave this for now as messing with coding / basic setting could put the control head in Component Protection. This module is the main brain of the MMI
00668 - Supply Voltage Terminal 30 Related to the 02272 - Quiescent Current Stage 1
All fine in my opinion. Just clear and go for a drive so the Battery Monitor can settle down.
Matt
Old 22nd December 2016, 06:42 PM
Are all 4 interior lights working , are the map reading lights in the mirror working
Is the brake pad wear indicator light on ?
The quiescent current could just be while you been testing it ...ignition being in doesn't half pull out all lot of amps ...battery volts soon drops
Take for a good run like Matty says then go into battery regulation think group 6 and look at s o c ...state of charge ...should be up to 100'% after half hour run .
My car had the code for exterior door handle .....it was the cause of my battery going low over night
Old 23rd December 2016, 06:53 PM
First I would like to comment about old battery, the battery in pictures have warehouse picking slip label on it so it cannot be original battery from the factory as those labels are attached when dealer orders part from warehouse and would not be on factory battery.
As for the previous owner putting back old battery there are several possible scenarios. I am not going into much detail at this time but I am sure you can imagine most of them.
In regards to electrician testing battery 12.1V seems very optimistic under load. How much load did he put on it? It's the kind of voltage you would see with engine off and lights on. Load testing should be at least 400A for this size of battery and even more. The voltage should be above 9.5V while cranking in most cases. My A6 drops to about 10.5V while glow plugs are on and to about 8.5V while cranking after preheat with a 4 years old battery which reports 60% health on conductance meter which recommends to replace battery.
But overall there is more to battery testing, 3 main parameters are capacity, cold start amps and internal resistance. Cold start amps(load test) can be tested quickly but require specialist equipment and battery to be off car. There is no hand held load tester that can put 800A load on battery and dissipate heat and basic 100-200A load testers will not show true performance for batteries of this size. They are OK if you want to test you bike or 1.0 Corsa but will not tell much for big batteries.
Capacity test is a bit long and would require draining battery with steady current over 20hrs, so for 100Ah battery you would put 5A load on it and measure the time it takes for voltage to drop belovw 11.9V or so. On a fresh battery it should be about 20hrs but if you get like half of that you can be sure it is duff.
Conductance test does not give direct result in CCA or capacity but will give you a good idea in general battery condition and it is very quick.
The new battery can also be duff if it has been sitting on the shelf too long and many of newer chemistry batteries require higher charging voltage, especially AGM batteries so if you fit advanced battery you might want to change voltage regulator on generator.
I am happy to lend you my conductance tester if you want although it only goes for batteries up to 800CCA but still should give god indication.
And finally I might be interested in you old battery if it is not too bad or too expensive.
Old 28th December 2016, 02:55 PM
All is well with the world, the new battery has fixed my problems and the car starts on the button, quick scan and my errors have gone, no battery warning lights or anything.
I find it mental that a battery can cause so much havoc with the cars internal systems, it's just plain weird how it affected everything from internal lights to MMI, tyre pressure sensors and so on.
Anyway, I wanted to wait a few days to make sure before saying thanks to all for your help in solving this, much appreciated!
Old 30th December 2016, 06:02 AM
Oli18's Avatar
Oli18 Oli18 is offline
Nice one! Mine did the same and all was sorted with a new battery!
Audi A8/S8 D2 Flickr Group
Old 30th December 2016, 09:30 AM
Good to hear yours is sorted, I however, typed too soon...
Last night coming back from Milton Keynes, I was talking to the missus about how good to car has been this year with no issues aside from the battery, lo and behold, by the time I got the the A5 roundabout some 4 miles away, the lights on the dash flickered, the clock said 00:00 and the car wouldn't come out of 6th gear.
I managed to get home (thank god for having a big v10 up front as 6th gear was still fine to pull away in) but she wouldn't change, either by putting her into tiptronic, paddles, Sport, Dynamic or via Neutral.
Once home I put her into park, then the selector and everything worked fine, gear changes were ok again - took her for a spin and silky smooth once more.
Turned her off, plugged her in, no gearbox errors or engine errors and the like, what caused that? have I got a duff battery?
I went into the boot to check the terminals were attached correctly (they were) and noticed that the side of the battery appeared to be a little wet, yet everything around the battery, trim and the top of the battery was dry - what was that all about?
Any ideas anyone?
I have had no battery warning lights, but she has been slow to start on these really super cold mornings (-4 yesterday)
