D3 front bumper removal - how to avoid ACC issues
Hi all,
I have to replace a front parking sensor which means the bumper has to come off. As it has ACC, what should i be thinking about? ... would i be able to avoid a calibration session with Audi if i don't turn on the ignition for instance? The guy that retrofitted ACC here took some pictures (scroll to bottom of the page)...it almost looks as though the bumper can come off without the ACC unit which appears to be mounted on the metal bar instead. Thanks, Oli
CURRENT: 2006 Audi A8 D3 4.2 Tdi QS - CLICK HERE FOR PROJECT THREAD: Audi Exclusive Azure Blue, Amaretto brown interior, facelift rear lights, S8 mirrors, B&O, ACC, Digital TV, glass sunroof, Fridge, Extended Leather Pack 2, wooden steering wheel & gearknob, keyless entry, keyless start, electric boot, softclose doors SOLD : 2000 FL Silver D2 4.2 QS - Solar sunroof, Bose, Blinds, NavPlus, Playstation, DVD, wireless headphones, iPhone AV connection, RS6 steering wheel, chrome mirrors, phone prep, xenons, servotronic steering, Rear screen, TV-in-motion, NavPlus Alu rings, S8 exhaust, S8 bonnet grille, 385mm D3 S8 brakes, rubber winter mats, De-badged rear, US rear indicator clusters, 20" Final Edition diamond cut wheels, 15mm Eibach Pro spacers (front), 20mm H&R hubcentric spacers (rear). Audi A8/S8 D2 Flickr Group Last edited by Oli18; 8th October 2013 at 09:23 PM. |
If you're careful... Then it should be OK. And as long as you line it back up exactly and don't disconnect the ACC, then it should be exactly as it was. Possibly even disconnect the battery to make sure it doesn't do anything daft.
Thanks again, Oliver
CURRENT: 2006 Audi A8 D3 4.2 Tdi QS - CLICK HERE FOR PROJECT THREAD: Audi Exclusive Azure Blue, Amaretto brown interior, facelift rear lights, S8 mirrors, B&O, ACC, Digital TV, glass sunroof, Fridge, Extended Leather Pack 2, wooden steering wheel & gearknob, keyless entry, keyless start, electric boot, softclose doors SOLD : 2000 FL Silver D2 4.2 QS - Solar sunroof, Bose, Blinds, NavPlus, Playstation, DVD, wireless headphones, iPhone AV connection, RS6 steering wheel, chrome mirrors, phone prep, xenons, servotronic steering, Rear screen, TV-in-motion, NavPlus Alu rings, S8 exhaust, S8 bonnet grille, 385mm D3 S8 brakes, rubber winter mats, De-badged rear, US rear indicator clusters, 20" Final Edition diamond cut wheels, 15mm Eibach Pro spacers (front), 20mm H&R hubcentric spacers (rear). Audi A8/S8 D2 Flickr Group |
Just do the -ve terminal as normal. It's only jumping or replacing battery that you have any funnies.
Hi,
Just wanted to give a quick update for other ACC owners thinking about removing the front bumper. There is no need to worry about the ACC - the reason is it isn't mounted in the bumper...it's actually sat behind it on the impact bar. So if you remove just the bumper itself, you're not touching the ACC sensor so no recalibration issues. Thanks, Oli
