Old 18th April 2009, 03:20 PM
Default How to change a V8 (I hope) :)
This thread is about my engine swap. It is not meant as a 'How To' as as I am making it up as I go along. I have removed a couple but never put one back.
I will be using a mix of AudiPages information and erWin printouts plus the experience I've gained from removing them. Now I know what your thinking; and yes I'm only doing it because I have no choice and I've always had suicidal tendancies.
So prior to starting I ordered up some parts from Audi. I have to swap the inlet manifold as mine is modded for LPG. So I have orderd the inlet manifold gaskets, Throttle Body gasket, Sump Plug Gaskets for engine and tranny, O-ring seals for ATF oil cooler pipes, Allen bolts for Torque Converter to flywheel.
After the engine arrived I have order up an exhaust seal, bolts and nuts.
Anyway a few photos:
As the engine came minus the cling wrap.
Mounted on the engine stand.
A shot most of us hope never to see...........
The first thing I had to do was remove the wiring harness as mine is modded with hard wiring for the LPG. Some kits have a plug in additional harness that goes between the injectors and wiring harness mine is soldered into the original. This was not as difficult as it may seem as being German its fitted in a logical and ordered manner.
Once the harness has been removed.
The harness as it came off.......... Lots of cable ties (Lots)
Out with the Inlet manifold, just 4 bolts and 4 nuts, a tap or 2 with a soft face mallet and ..........
Something to polish?
Next up is the cleaning. AS I have the engine on the stand I'm also going to do some preventive work and replace most of the hoses that are hard to do when in the car.
Old 19th April 2009, 07:32 AM
Oli18's Avatar
Oli18 Oli18 is offline
Good luck with this Conan ....this will be an interesting thread to keep an eye on!
I take it you want it all done for the June meet?
-Oli
Audi A8/S8 D2 Flickr Group
Old 19th April 2009, 04:00 PM
-Oli
I want it by the early May bank holiday..........
Old 20th April 2009, 09:55 AM
Nice Job Mike... This is going to be really interesting reading....
Always good to see things arrive the other end of the country in one piece
We never get to see anything of engines once they've been shipped, and as this engine came from a car than both David and I personally owned, its all the more interesting to see how she comes on.....
Old 20th April 2009, 11:39 AM
A8 Doc A8 Doc is offline
Are you in the North East? I have an engine stand you can borrow for 2-3 weeks if you need to?
Need it back in about a month tho as my M3 Project is arriving. Yey!
Or Machine Mart has them for £40....
Old 20th April 2009, 11:41 AM
I have never changed a Audi V8 engine so take this into consideration BUT:
One all the engines I have swapped behind the flywheel there is a rubber seal that goes over the crank and holds the oil in the engine. Prob about a fiver, but a perfect time to swap. Will take half hour to do properly but saves an annoying oil leak all over your torque convertor in the future?
Old 20th April 2009, 03:54 PM
I'm in the South West. But thanks for the offer, greatly appreciated. I will prolly get one from Machine Mart.
Old 19th April 2009, 03:45 PM
Default OCD kicks in.......
A few hours cleaning and I am as relaxed as John Holmes pecker after 8 hours filming..........
Going to have to buy myself one of these engine stands for the lump I take out. Now what should I do with it? After cleaning it of course....
Old 26th April 2009, 05:05 PM
Default Yep! Definately downhill.
My wife has been saying I have been going downhill for sometime. Well this weekend I have mostly been going downhill.
I couldn't resist it and decided that some cleaning could be done. Started in the engine bay........
Then onto a bit of electric welding which saw me finish the repairs/mods to the loom......
The on to the engine went the loom. Has to ring a friend at one point as I was near tears again when I had 2 extra plugs and no where to put them. they were that lamba connectors and the cats are in the corner! Doh....
I also started on the suspension and of note the rear lower control arm can not be removed without lowering the subframe as the bolt can't come out far enough. So i have swapped it end over end, bit fiddlt but possible as seen here........
Then it was the turn of the front wheel arches. Last year I ran through some paint and didn't realise it until it was rock solid. A phone picture as I forgot my camera this morning...........
I used W&D wet (400 and 800) and just gently rubbed away. I'll get a better pic of the finished effort tomorrow.
Disclaimner:
I should not be followed even by the curious. I do not 'know' what I am doing.
Old 26th April 2009, 07:03 PM
Some great progress so far Mike.
Subject to cleaning time, should be in and running in another day or two.
Tags
4.2 v8, engine swap, s8 ahc
