Old 28th November 2016, 07:47 PM
Originally Posted by Mechcanico Lee View Post
Should battery energy monitor of been in the scan Snap ?
Quite right - There are quite a few modules missing aren't there? Park Brake, Parking sensors, Engine, ABS, Radio, BOSE DSP( if fitted) Battery Manager etc...
Old 28th November 2016, 08:41 PM
Turbo Tony's Avatar
The LEDs on the tops of the door cards that flash red - are they supposed to flash constantly?
Mine seem to slow to flash only once every 10 seconds or so, maybe longer (my memory is fading!). Does that mean the car is gone into low-power, battery conservation mode, or is it normal?
Oli, what do your LEDs do?
Storytellers Villa Orlando
2008 Audi S8
Old 29th November 2016, 05:47 PM
Default Some General comments from a fellow battery sufferer ...
I've had what appears to battery drains for over 4 years with my 2005 3.0TDi A8. Mine's still not fully sorted but my advice would be to :
1) Clear out all the faults/DTCs so you know what is actually currently faulty on the car.
I'm not sure much reveals itself with a scan when there's a battery drain anyway, but you've got too many faults in your scan to see what might be going on currently! Not sure why you haven't got ECUs 1 [Engine], 3 [ABS], or anything above ECU 37 in your log. The most useful to see would be the Battery Manager [BM] ECU - 61. BM DTCs might be useful and some SW versions of the ECU are buggy and should have an update. [BTW; as well as missing some key ECUs, your logs seem to incorrectly identify Software levels as Hardware levels].
2) Fully charge you battery with a smart charger.
You can do this on the car without disconnecting anything but do it across the battery positive and the negative 'bar' connected to the BM. Will take about 10 hours - best done overnight. When charged fully, that is with the smart charger 'bulk' and 'topping' charge, battery volts with a voltmeter should be about 12.6V. Note - I'm not sure the BM that all A8s have correctly allows the battery to be properly 'fully charged'. Audi don't publish any specs. for the BM, so it's difficult to determine if it's charging with the 'bulk and topping' charge that lead acid batteries need now and then.
3) Check the battery volts with a voltmeter now and then.
I bought one of those LED display voltmeters that plug in to the cigarette lighter socket. These aren't super accurate but you're checking voltage changes rather than actual values. Leave it in the front socket all the time and you can check the battery voltage by just looking through the window. [I left it in while I was away in Italy for the week and got my neighbour to look each night when it was dark so he could see it easily. On that ocassion I got virtually no voltage drop all week - went down about .1 Volts.] Bear in mind that approximately, 100% is 12.6V, 50% is 12.2V and 0%[flat] is 11.9V.
Alternatively, just check the battery voltage with a voltmeter across the battery terminals every now and then. Either of these techniques will at least indicate what the degree of 'voltage loss' is.
And then all that work won't necessarily show you what's going on! It's easier if one circuit is causing the drop; the recommended technique is to measure voltage across the fuses. The voltages should all be zero as the circuits should be 'dead' but a fuse with a small millivolt drop indicates a 'live' circuit. [But this won't normally spot the device that comes on and goes off again later].
Finally if/when replacing your battery make sure you get a battery with an appropriately high CCA [cold crank amps]. This needs to be higher for diesel engines as they turn over less easily; the A8 diesels should have at least 850A CCA.
Julian
Old 29th November 2016, 05:50 PM
The LEDs do flash constantly but are turned off by the Battery Manager when it detects a severe voltage drop.
Ignoring the first 30 secs, I believe they flash every few seconds [2 -3 in my case]. Not sure if they flash less often before being turned off ...
Julian
Old 29th November 2016, 05:54 PM
Turbo Tony's Avatar
Julian, that's some priceless information. Thanks!
2008 Audi S8
Old 29th November 2016, 05:59 PM
Should battery energy monitor of been in the scan Snap ? .............. is on my car anyhow .....me leaving my auxillary burner going for to long often puts quiecent volts under codes in there ......cars is lovely and toasty in the morn though hehehe
All 'D3' A8s have a battery manager ECU, albeit with different hardware and firmware levels. Audi have never published the logic of the BM or what issues the different levels fixed. There ARE BM ECUs that need a firmware update; these are H11 versions on 2004-2005 cars.
And different AUX heaters are installed on petrol and diesel cars .
Guess you have a petrol A8 Lee; these have heaters that can preheat. Diesels have a simpler one that only heats the circulating water in winter.
Julian
Old 29th November 2016, 08:47 PM
4.2 tdi Julian , with timer mode enabled in mmi and extra electric water pump fitted , I did it first job on the car when I got it .
One of best mods on the car , I set it in the morn for 30 min run , it's fully defrosted and toasty warm inside , the diverter valve is just not needed .
Old 17th December 2016, 05:35 PM
Oli18's Avatar
Oli18 Oli18 is offline
Hi,
Thanks for all the advice so far and sorry for the late reply...been a crazy 2 weeks leading up to Xmas at work.
Good to know i'm not alone in this. I used OBDEleven for my last scan and have since fired up an old PC with VCDS to do a new scan.
I thought i'd follow the advice and start with getting a new battery. I've had the car 3 years and thought it would be good to eliminate that as a factor first.
This was my old battery [part number 4E0 915 105 A]:
I bought an OEM battery from TPS for £150 [part number 4E0 915 105 DL]:
I used this video to code the battery in VCDS:
https://www.youtube.com/watch?v=IJAScg6JrYI
And it was accepted first go:
There's many faults in there. I'd suspect quite a few of them are old and related to low battery but the one that jumps out to me is the over temp of the air compressor.
That tells me you quite possibly have a leak in the suspension somewhere. If there is a leak then the suspension will be trying to level it's self periodically while your away from the car.
I do think know however if it will run the compressor or just use what's in the accumulator.
The other thing that jumps out is the instrument cluster fault. It's vague but I have seen on two occasions now where a faulty cluster keeps the can bus awake while the car is locked and that flattens the battery.
You can easily tell if the can bus is awake by looking to see if the lights around the gear shift are lit up at night when the car has been locked for more than 10 mins
Thanks Delboy. I'll take a look and let you know!
I will post another VCDS scan tomorrow and will keep you posted on progress. I'm off to Holland next week for Xmas so would love to have this sorted.
Oli
Audi A8/S8 D2 Flickr Group
Old 17th December 2016, 07:12 PM
Oli18's Avatar
Here is a fresh scan using VCDS below.
I got in the car after i drove it 3 hours earlier. I thought i'd check the battery regulator and went into the 'advanced measuring blocks' and it showed 12.2V...and this dropped to 11.95V over 20 mins of scanning. Is this normal?
Thanks,
Oli
Saturday,17,December,2016,20:13:54:17815
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.4.2
Data version: 20161129 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ4E26N019357 License Plate: OVB2
Mileage: 206770km-128483miV3 Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 11 31 13 15 16 17 18 19 1D 1E 25
34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77
VIN: WAUZZZ4E26N019357 Mileage: 206770km-128480miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Not registered 0001
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 4E1 910 409 A HW: 4E1 907 409
Component: 4.2L V8TDI A000AGMª0070
Revision: --H01--- Serial number: AUX3Z0F0383869
Coding: 0011773
Shop #: WSC 00759 210 86480
VCID: 2241C55DFD8A6652FF-8076
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 P HW: 09E 927 156 B
Component: AG6 09E 4,2lTDI RdW 0030
Revision: --H01--- Serial number: 0076831
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 30653F15A366C4C279-8064
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F0383869
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58B5A7B5EB56FC82D1-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 103
Mileage: 206768 km
Time Indication: 0
Date: 2016.12.17
Time: 19:56:22
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
VCID: 244DC345E79E68628D-8070
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300AC067562505
Coding: 0000002
Shop #: WSC 12345 111 45725
VCID: 3A711D3D751A0E92C7-806E
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 318HI037505510
Subsystem 3 - Serial number: 7429.08.030000000000010000ÿ
Subsystem 4 - Serial number: 010000ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000088042
Coding: 0022563
VCID: 1C3DFBA5DFEE50A235-8048
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 103
Mileage: 206778 km
Time Indication: 0
Date: 2016.12.17
Time: 20:07:19
Freeze Frame:
Temperature: 30.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0133122
VCID: 3669090D4102EAF223-8062
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8049216
Shop #: WSC 00000 000 00000
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI A000AGSª0070
Coding: 0011773
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0011154
VCID: 254BDE41ECA4916A9A-8070
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H12 3610
Revision: 91H12360 Serial number: 0037P000DLH0
Coding: 0431707
VCID: 2757D44996A8837AA8-8072
Subsystem 1 - Serial number: 63328RB400E24D6EV
Subsystem 2 - Serial number: 63428RB400E2571CK
Subsystem 3 - Serial number: 63528RB400E2571DM
Subsystem 4 - Serial number: 63628RB400E256F4R
Subsystem 5 - Serial number: 63729RB400D364F8W
Subsystem 6 - Serial number: 63829RB400D364A8S
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112151
VCID: 65CB9E41AC24516A5A-8030
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 980 N HW: 4E0 920 980 N
Component: KOMBIINSTR. VDO H70 0410
Revision: D02 Serial number: AUDID3F0000091
Coding: 0000403
Shop #: WSC 31177 001 1048576
VCID: 3261351DAD6AF6D20F-8066
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 60685 km
Time Indication: 0
Date: 2008.10.08
Time: 08:32:47
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 F
Component: Heizgeraet H07 0110
Revision: 0000000C Serial number: 00000009006406
Coding: 0000001
VCID: 1A31FDBDD5DA2E9227-804E
2 Faults Found:
01412 - Glow-Plug with Flame Monitoring (Q8)
008 - Implausible Signal
02251 - Heater Unit Locked
000 - -
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 F
Component: Gateway H11 0090
Revision: 11 Serial number: 19004061088029
Coding: FEFFFBDF2B7504
Shop #: WSC 11111 123 12345
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 206778 km
Time Indication: 0
Date: 2016.12.17
Time: 19:55:21
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 206778 km
Time Indication: 0
Date: 2016.12.17
Time: 19:55:21
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 HW: 4E2 905 218
Component: FPI_1 H06 0060
Revision: 06000106 Serial number: 11082004063652
Shop #: WSC 00048 210 176595
VCID: 5EB9B1AD897202B29B-800A
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H20 0850
Revision: 00000000
Coding: 010000
VCID: 2B5F28794A40A71A4C-807E
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 103
Mileage: 206768 km
Time Indication: 0
Date: 2016.12.17
Time: 19:56:22
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A512D7D85BABE12B7-807E
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063342
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H47 1060
Revision: 00000000 Serial number: 364AS067525548
VCID: 3B7F18397A20379ADC-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H03 0090
Serial number: 00000534600055
Coding: 0036036
VCID: 1D3BF6A1C4F459AAC2-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032622
VCID: 2045CF55F3867442E9-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601170155
Coding: 0004349
VCID: 2855D7759BB68C02A1-807C
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 D HW: 4E0 035 466
Component: BO_D3 H06 0320
Revision: 11S00002 Serial number: 00504060002262
Coding: 0000023
Subsystem 1 - Part No: 4E0 910 465 B
Component: BO_D3_SLAVE H31 0310
Subsystem 2 - Serial number: 01901060000773
Subsystem 3 - Serial number: 0219.01.060000000100030013ÿ
Subsystem 4 - Serial number: 030013ÿ
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000078312
Coding: 0010101
VCID: 1E39F1ADC9F242B2DB-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032622
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0001031
Shop #: WSC 00011 888 96745
VCID: 1F47CCA9CEF84BBAD0-804A
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000006
VCID: 3D7B1621643439AAE2-8068
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 304AS067613997
Coding: 0000001
VCID: 31633A11A86CCDCA76-8064
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 A HW: 4E0 919 148
Component: R0078 TVhybridTuner 0280
Revision: R0H05000 Serial number: 76300700425102
Coding: 0000003
VCID: 2143CA51F88C7D4AE6-8074
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000010029
Shop #: WSC 00759 210 61239
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 360701103L
Coding: 303030393135313035444C5641303336303730313130334C
Shop #: WSC 12345 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032622
Address 65: Tire Pressure
Cannot be reached
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000601130467
Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032622
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720602003606
Coding: 0301008
VCID: 234FC059E2906F5AF4-8076
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H13 1130
Revision: 00000000 Serial number: 00000007608675
Coding: 0010900
VCID: 2C5D2B658F4EA02245-8078
End-------------------------(Elapsed Time: 04:17)--------------------------
Old 17th December 2016, 08:13 PM
It depends on load, as you were doing VCDS scan I assume you had ignition on and a few consumers like fan etc so voltage should be OK. Without load you should see about 12.6V on the fully charged battery but with a load it will drop depending on load. When you have glow plugs on and starter running it could even drop below 9V but with light load it should not drop muchbelow 12V
