Old 19th March 2010, 09:58 PM
Right, well transmission tunnel covers are on with out a problem, and I've now been able to take it for a test drive, which was succesful so I think we can consider the RNS-E transplant a success
When you first set off the arrow on the map will likely be out, and will keep being out for a little while. Just keep driving and it will calibrate the speed pulses from the GALA feed against the GPS position and figure it out. Drive with it on maximum zoom so you can see how accurate it is and within about 10 mins, it should be spot on. Mine is
Heres a quick boot shot of the new TV tuner on top, with the bluetooth module tucked down the side....
Now is it just me, or does that look rather tidy ?
Old 19th March 2010, 10:11 PM
CliveH's Avatar
CliveH CliveH is offline
Default Looks rather tidy to me!
Well, what can I say? It certainly wasn't plug and play, but you make it look so easy...
As always, a superb write-up and the best result possible. Nice work Ian
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs
Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten
Old 20th March 2010, 06:43 AM
Looks factory to me Ian. Top write up and added to sticky.
Old 22nd March 2010, 07:16 PM
Default RSE.... with RNS-E...
Last little bits now.....
I spent a good long time pi55ing around trying to get the rear seat entertainment to work, and was going round in circles... I have 2 AV inputs on my Tuner, and no matter what I did, AV1 wouldnt work properly... Alas, this was fundamental in my overall plan and annoyingly I eventually tracked it down to a faulty AV adapter for the TV tuner that I had bought - They had got of the pins in wrong holes hence I have no AV1... Fixed that and hey presto, shes alive...., here we have the 10 discs DVD changer in the boot showing on both widescreen displays...
Here is another photo of the drop down Audi screen in the rear, which is made by Sony (model XTL-750w) and is also used in the BMW X5 RSE kit, but I digress - Mine was black, so I repainted it, but got it a little too light, but I can always darken it again later if the need takes me:
and finally, another problem I have is that the boot mounted LPG tank prevents me from fitting the pukka armrest cubby hole that houses the DVD changer control an playstation controllers. Well, I think the PS1 as probably had its day, so I'm happy to forego that, and the DVD changer control, well I popped that here:
Its right up behind the rear lights so the driver cant see it at all from the front, yet the rear passenger can see if perfectly by just looking up.... I nicked the carrier from an A6 RSE kit as in the Avants they stick the controls on the roof just like this...
ID:	932   Click image for larger version
ID:	933   Click image for larger version
Old 22nd March 2010, 07:26 PM
Oli18's Avatar
Oli18 Oli18 is offline
V cool!
Audi A8/S8 D2 Flickr Group
Old 22nd March 2010, 07:30 PM
Default ooops, almost forgot
For those with the early RNS-D or RNS-C units, you have a small speaker down in the driver B pillar trim for the navigation directions and the phone speaker.
Later models 2001/2002 dont, it all comes out of the standard speakers.
The RNS-E is the same, and the speaker is now unused.
However, it does need to to know where the driver is sat as it bleats the driving instructions out of his/her speaker, and by default factory units come coded for LHD cars, so she shouts her self stupid at the poor passenger that gets the shock of their life...
Its a simple recode, whip out vagcom, go to adaptation and channel 136. Modify it as required. Mine wouldn't accept 2632 for the RNS-E Basic, but took the 00013 for RNS-E high quite happily. No idea what the difference is, but my woman now comes out by my feet, and not out of the glovebox...
Old 22nd March 2010, 07:36 PM
That makes sense now! I thought I was going mad thinking the directions were coming from the passenger side of the car.
Very clever fitting, it all looks great however I have never really liked the look of that Audi RSE. I had the opportunity to have it and passed as I actually think the screens look better in the headrests. It doesn't look very OEM. 10 Disc DVD changer is very cool however. That looks great Ian, top work and a huge thank you for the write up. I owe you one
Old 22nd March 2010, 08:10 PM
I agree that the screens *look* better in the headrests, and two seperate screens arguably give more functionality than a single one, however they are more obvious and more prone to theft. I know for a fact we've had calls before from people wanting 'new hearests' because they've had them nicked for the screens....
I like the Audi kit because its so discrete.... Just like the rest of my 8..
Old 5th May 2010, 01:39 PM
Why is this not a sticky!?
Old 5th May 2010, 05:05 PM
Cos the senior admin has not told the junior admin to do it yet!
Far be it for a mere Librarian to tell an 8 God to do his own sticky's!!!!
However, if you look in the forum sticky you will see it is linked!
