Old 9th May 2020, 04:42 PM
Ronin Ronin is offline
Default Dimensions of passenger footwell relay box cover needed
Would any of you have a drawing or dimensions of the piece of wood which covers the relay box on passenger foot well? Mine is so deformed I can't even use it as a stencil to make a new one
Old 9th May 2020, 04:50 PM
Sean almost certainly will, he made some very nice replacements.
Hopefully he'll be along soon and can help. (I've just PM'ed him this thread)
Old 9th May 2020, 05:23 PM
Mark did too, so he may be along soon
Old 10th May 2020, 09:44 AM
I did: http://forum.a8parts.co.uk/showthread.php?t=11673
... but unfortunately I never took measurements. I just used the old one as a template.
If nobody has measurements I'll pop the cover off and measure it when I have time.
Old 10th May 2020, 10:33 AM
I've been using my least-ruined one as a template to cut replacements from marine ply. I'll see if I can find it and get some pics with dimensions.
Maybe if I can transpose it to CAD I could make a printable template?
Old 10th May 2020, 11:41 AM
Yes please!
Old 10th May 2020, 01:12 PM
A bit late to the party, but like Mark and Michaela, I just used mine as a template. Sorry.
Old 14th May 2020, 10:57 AM
I also just used the swollen MDF as a template and made one out of 12mm marine ply.
Old 14th May 2020, 03:22 PM
I know this is a bit low tech, but I took mine out and measured it! Attached are photos with dimensions written on the cover itself (in cm), taken in two different lights, so I hope enough of them are clear to be helpful.
PLEASE NOTE: the photos are rotated 90 degrees relative to the orientation in the car! The 35.5cm line is the bottom of the cover.
Let me know if there's a measurement that's missing.
ID:	23322   Click image for larger version
ID:	23323   Click image for larger version
ID:	23324   Click image for larger version
ID:	23325   Click image for larger version
ID:	23326   Click image for larger version
ID:	23327   Click image for larger version
ID:	23328   Click image for larger version
ID:	23329   Click image for larger version
ID:	23330   Click image for larger version
Old 14th May 2020, 03:56 PM
I spent a little time the other day transcribing mine in to CAD. That was easy. Problem is, now all I can do with it is 3d print it or send it to a CNC machine! The idea was to make a 4-page document that you can print, stick together and then cut along the line to make a template. Trying to output a 3D model to a 2D PDF however, is apparently impossible
However, while typing that ^ I just had an idea which I will try later
