Old 12th August 2016, 05:37 AM
milenajdoski milenajdoski is offline
Default Problem with 2 small lcd (odometer and clock)in instrument cluster
I have a problem with these 2
When cold all ok
When warm they tent to become losing some lines and imposible to read the numbers on them
Any fix?
Thx
Old 21st August 2016, 11:11 AM
you would need to take the dash out and send it away to someone like -
http://www.bba-reman.com/gb/content....anel_dashboard
or
http://www.clusterrepairsuk.co.uk/re...repair-service
to get it sorted
Old 21st August 2016, 06:43 PM
Joe2.0E Joe2.0E is offline
Any idea on the cost of such repairs ? Would a used cluster possibly be a cheaper option ? There would be quite a few D2's broken for spares at this stage.
Obviously, the odometer reading would need to be corrected with a used cluster.
Old 21st August 2016, 07:11 PM
That aside, if it's a FL D2 then the immobiliser encoder is built into the cluster so that's why it's better to get it repaired. I have no idea of the cost but I would guess at about £150, I would enquire with both the companies linked to
Old 22nd August 2016, 10:24 AM
The used cluster mileage cannot be corrected. From what I've read previously, once it goes beyond 100km, it can't be changed.
Old 22nd August 2016, 01:18 PM
A 'mileage adjustment' service provider can get around the bars on dealers altering mileage beyond that limit.
These circumstances are the only ones I'd consider using such an outfit to alter the mileage, but as per Neil's suggestion I would prefer for the original cluster to be repaired. it's unlikely to be difficult/time consuming and they'll give you a warranty for the work.
