Old 12th May 2018, 07:28 AM
North2007 North2007 is offline
Default Upgrade Brakes?
Team, Im looking to improve my pedal sensitivity. I dont believe my brake have a fault, just the automatic gearbox and overall design. After driving my sons A3 the A8 pedal softness is very obvious. Is there any merit in upgraging the servo or are all the 8s same? Or maybe swapping out the rubber flexi pipes to help improve the lack of sharpness? Im no expert, and would like to hear your thoughts/ experiences. Steve
2003, A8 D3 4.0 TDI
Old 12th May 2018, 07:42 AM
Rubber flexi pipes is a good start and is cheap. It made a significant difference on my Passat as they must have been ballooning but I have only done the rears on the A8 so far which didn't make any difference.
They do get a bit soft with age and only about £7 each, but lots of part number variation, so be really sure you get the right length for your model/year.
Old 12th May 2018, 09:02 AM
I was thinking braided stainless steel
2003, A8 D3 4.0 TDI
Old 12th May 2018, 10:28 AM
I would also change your whole brake fluid for new first before you do anything else and re-bleed. you are supposed to change it every 2-3 years as the properties lessen for best performance as it gets older and it may also make a difference to how the pedal feels
Old 12th May 2018, 12:42 PM
Ever so slightly OT Neil, but do you notice a big difference in the braking between the D2 and D3? I changed my brake fluid on the D2 last month prior to the MOT and expected it to feel a bit sharper, but didn't notice anything. The brakes were obviously okay as the car sailed through the MOT. Maybe I'm not driving fast enough to notice.
Just wondering if doing what North2007 suggests would help, with the braided stainless. Would also look better.
Old 14th May 2018, 10:29 AM
Its hard to say now really Sean, as I have upgraded the standard D2 brakes on mine to W12/S8/Bentley Big Boy brakes, I can definitely say that they are better than the standard D3 brakes!
Old 14th May 2018, 12:47 PM
I forgot you had those monsters on the D2.
