Go Back   A8 Parts Forum > Our Other Audi Friends > A4/S4 B6
A4/S4 B6 2001-2005
Old 3rd February 2020, 07:53 PM
Zip's Avatar
Zip Zip is offline
Thumbs up 2005 B6 S4 Cab new owner...
Picked up on Friday. Loving it already. Black with silver leather, RNS-E, Bose, Carbon trim, cruise. Excellent cosmetically, interior is superb...no wear on the buttons.
Load area partition thing is not moving up and down, and the cover bit seems to be missing. Easy to fix?
Rear ashtray lid is broken...I'll try and source another. Headlight switch a bit scratched...ordered a new cover already. Footrest missing, and battery cover broken...replacement bits already ordered.
Headlights are the worst bit ...full of condensation, and surface of lenses quite lumpy and grey. Light output from dipped beam is shockingly awful. Done lots of googling, and ordered a 3M refurb kit. I see you can upgrade the lights as well. Need to tackle the condensation though. Any advice.
It came with winter tyres. Would like a set of the Audi BBS CH wheels for the summers...anyone got some they don't want? 8jx18, et45 ish?
Oh and it has 104k miles, but had new engine at 47k. And it was cheap.
Any advice? Fancy a lower front lip spoiler, fruitier exhaust.
Cheers,
Zip
Old 3rd February 2020, 08:18 PM
Maxton Design do the front splitter, plus a few other bits. See below:
https://www.maxtondesign.co.uk/audi/...itter-au-s4-b8
Old 3rd February 2020, 08:27 PM
Polishing the headlight lenses will probably make zero difference to light output I'm afraid, the xenon units have silver coloured plastic "reflectors", they will now be black and not reflecting anything :/
I had new projectors fitted into my 2004 S4, bi-xenon units from a Lexus of some sort, made the output awesome. You can get aftermarket projectors now that bolt straight in I believe.
Still had to polish and clear coat the lenses, which didn't really last that well.
Short of a new set of lights, not an ideal answer I'm afraid!
Old 13th February 2020, 07:55 AM
1781cc 1781cc is offline
Hey, welcome to the cabriolet club, I am currently running a 3.0TDI A4 cab in B7 format, but I've had 2 4.2 B6 S4s in the past - good engines if you can avoid the timing belt issue, hopefully the new engine and guides will have solved this - just keep your eye on oil consumption.
I guess you know about the aux rads, DMF/Clutch and other S4 common issues...
Come over and join us in the A4 Cabriolet Club UK - don't be put off by the name, there are S4 and RS4 owners in the group but the information is huge.
Splitter - just get the MK1 Cupra R splitter from TPS, looks much better and cheaper than any other option - See pic below
Loads you can do to these things, I recently fitted Supersport seats - it was a wiring headache though!
ID:	22859   Click image for larger version
Old 14th February 2020, 01:11 PM
Zip's Avatar
Zip Zip is offline
Question
Hi. Thanks...already on the A4 club FB page.
How have you fastened the front lip on....just self tappers? Looks like there used to be some sort of lip on mine, as there are loads of pop rivets rattling around left behind.
Zip
Old 14th February 2020, 01:13 PM
Zip's Avatar
Zip Zip is offline
Thumbs up
Oh, and managed to source a Milltek non-resonated second hand....fitted it on Wednesday, and sounds lovely
Zip
Old 14th February 2020, 04:44 PM
Zip
Yeah, Self Tapers, I am guessing some previously mounted one on yours and then took it off, its easy to do but needs a little trimming in the centre, best to offer up with gaffe tape to test and hold in place, then screw in properly when happy.
