Old 16th December 2020, 04:34 PM
Default Audi S8 D3 FL Widescreen Instrument Cluster
I have for sale a widescreen instrument cluster for the S8 D3. I removed it from my '08 S8 when retrofitting ACC to the car. The part number is 4E0920951M and was manufactured in 2007. As such, it has the needle sweep, as well as the speed in the centre display. Attached photos show the widescreen display in operation.
Please note that this is a UK spec instrument cluster, with the speed marked in MPH, as well as KPH. Also note that component protection is inbuilt and this will require removal when installed. I have also included a photo of what it will look like with the component protection active.
It also has the little roller blind thingy at the bottom for when you adjust the steering column, and I can throw in the steering column switchgear as well that I replaced in the S8.
Name:	IMG_7385 (Large).JPG
ID:	24854   Click image for larger version
Name:	IMG_7386 (Large).JPG
ID:	24855   Click image for larger version
Name:	IMG_2261 (Large).JPG
ID:	24856   Click image for larger version
Name:	IMG_2262 (Large).JPG
ID:	24857   Click image for larger version
Name:	IMG_2264 (Large).JPG
ID:	24858   Click image for larger version
Name:	IMG_20190504 (Large).jpg
ID:	24859   Click image for larger version
Name:	IMG_20190424 (Large).jpg
