Fluid loss front offside corner
Chaps, I'm losing some kind of fluid from the front offside corner.
I imagine this is washer fluid, are there any existing threads / how-tos on to access, diagnose and repair please? (I did do a search but could not find what I was looking for) |
There were a few comments in this thread that may give you a heads up:
Item 23 onwards: http://forum.a8parts.co.uk/showthread.php?t=16912
Paul Gosport UK ________________________ Audi S8 2002 FE Avus Silver / Extended Red Leather. Daily Driver: BMW 3 series GT - Just more practical for my camping trips! |
Its 2 grommets that you have to replace, forum sponsors sell them. its also a good opportunity take the washer fluid tank out and wash out any junk out of it with a kracher etc.
thank you both
Any theories why it should start leaking while sat in my garage? |
Good news: it's not leaking washer fluid
Bad news: it's coolant Discussions with our resident Doctor suggest it is probably the oil cooler pipe. I've not had chance to get on the ramps and have a look, so have just ordered the parts (they'll come in useful one day if not now!) and booked in with a local mechanic over the next couple of weeks, hopefully fixed and sorted in time for the annual meet. My simple brain still cannot understand why it should start leaking being tucked up in a warm(ish) dry garage |
I recall comments that often it's as likely the grommets/washers around the pipe as the (definitely fragile) plastic pipe itself.
Mine had been leaking for ages (years!) before MJ replaced it during its overhaul, though I don't recall how damaged it was.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Usually the plastic cracks in the o-ring grooves so the pipe comes out in three pieces. The cracks propagate from the sharp edge in the grooves, eventually going all the way round, and then coolant slowly seeps out. It is fully constrained by the engine block and cooler housing so it can't catastrophically fail. It just dribbles in varying degrees.
Replacement pipe has still not turned up, starting to look doubtful the D2 will make the annual meet, the risk of me showing up yet again in a BMW is increasing each day that goes past
It might be worth providing the following link to your mechanic so that they have knowledge of what's involved. This was for work on a 4.2 32V engine, with notes at the bottom for the 40V ones. MJ may have a much better insight on any other possible snags along the way: http://www.audipages.com/Tech_Articl...reinstall.html
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
If its confirmed to be the oil cooler pipe, I'd take it to the meet and just top up as necessary. It can't fail catastrophically and as Andrew noted, they can run for many years with the pipe cracked with no adverse effect than marking their territory overnight
The only activity that failure would stop me doing is taking it on a track |
