Go Back   A8 Parts Forum > A8 D4 > D4 - Axles, Brakes, Suspension and Steering
D4 - Axles, Brakes, Suspension and Steering Brakes, Springs, shocks, steering racks, steering columns, suspension arms, wheel hubs etc.
Old 6th April 2024, 05:13 PM
Saff Saff is offline
Default Hub bolt torque
Hi all.
Can anyone tell me or point me towards the front hub bolt torque please? Its for the bolt that goes into the end of the driveshaft. I have a feeling its about 140lb/ft +180 degrees but could do with the correct data,
Thanks Steve.
2010 D4 SE Executive 4.2 TDI
Old 6th April 2024, 10:26 PM
Pretty much spot on. According to the following PDF in the 'D4 Technical Info' section, it's 200Nm + 180 degrees:
28-Service Manual Running gear front-wheel drive and four-wheel drive.pdf
Old 7th April 2024, 07:16 AM
Yet again, thanks Sean!
