Originally Posted by GlynH
Reading up it would appear that you get a warning in the DIS round 1500 miles to empty, again @ 600 miles and then when you hit zero miles if you turn the engine off it won't then start up again until the AdBlue has been refilled.
Also you have to put a minimum of 3.8 litres or so to get it to register that anything has been added.
I don't know anything about this stuff other than it being another 'additive' to worry about, so bear with me.
Would the 3.8 litres be the minimum amount from empty, and not at any level?
You mention that the DIS gives you a warning at 1,500 miles. Would this be like the min. mark level for AdBlue, in the same way as you have min. marks for brake fluid or washer fluid.
If you then fill it up to the top, it should then clear the DIS, irrespective of how much AdBlue you put in. It just seems weird that you have to put in at least 3.8 litres to clear it. Just trying to think how it would measure the amount going in.
Be interested in hearing the outcome.
If all else fails, you could always get it coded out!
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
Sold!
2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
