Go Back   A8 Parts Forum > A8 D4 > D4 - Fuel and Exhausts
D4 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again
Old 2nd May 2018, 03:13 PM
Originally Posted by GlynH View Post
Reading up it would appear that you get a warning in the DIS round 1500 miles to empty, again @ 600 miles and then when you hit zero miles if you turn the engine off it won't then start up again until the AdBlue has been refilled.
Also you have to put a minimum of 3.8 litres or so to get it to register that anything has been added.
I don't know anything about this stuff other than it being another 'additive' to worry about, so bear with me.
Would the 3.8 litres be the minimum amount from empty, and not at any level?
You mention that the DIS gives you a warning at 1,500 miles. Would this be like the min. mark level for AdBlue, in the same way as you have min. marks for brake fluid or washer fluid.
If you then fill it up to the top, it should then clear the DIS, irrespective of how much AdBlue you put in. It just seems weird that you have to put in at least 3.8 litres to clear it. Just trying to think how it would measure the amount going in.
Be interested in hearing the outcome.
If all else fails, you could always get it coded out!
