Old 1st May 2023, 04:23 PM
Originally Posted by Versace View Post
Is it possible to do a retrofit but with cluster/speedo without the red LEDīs? I do have the "widescreen" speedo but obviously without the LEDīs for the ACC.
I do have an ACC speedo, but it does not help, its for an A8 4.2 and I would like to retrofit it in an S8.
Not sure about retrofitting ACC without the correct cluster, but I have two clusters that may or may not be of use to you, depending on exactly what you want. Your signature says you have a 4.2 but you say you want to install it in a S8, so I'm a bit confused.
I have a standard widescreen S8 cluster that I removed from my S8 when doing the ACC retrofit.
I also have a widescreen ACC cluster that came out of a W12 D3 from A8parts, when I got all the other necessary parts, but hung on until I got the S8 ACC cluster.
I have photos of them somewhere with part numbers, so will post them up when I find them.
EDIT: Well that was easier that I thought. I actually advertised them for sale ages ago on the forum, with all the relevant information. They can be found at these links:
S8 Facelift Cluster
A8 Facelift ACC Cluster
Last edited by steamship; 1st May 2023 at 04:27 PM. Reason: Links to Ads with Photos
