Old 19th January 2024, 05:47 PM
At the same time the ABS and traction control lights appeared….not sure if coincident?
I just got the car back from DS Autowerkes and the indicators from the replacement squib are now working, however I still have an ABS and traction control light on the dash….and I now also have a large flashing red warning circle on the DIS which I didn’t have before.
The following thread hints at changing/removing the steering wheel will throw up and ABS and traction control lights. There is a procedure listed for resetting the Steering Angle Sensor.
https://www.audizine.com/forum/showt...tes-Don-t-work
However, your mention of the large flashing red warning on the DIS would imply something more serious, as it's only one of four such red warnings displayed on the DIS.
Just found another post which said that the ABS loses its coding when the slip ring is disconnected! The following video from Ross-Tech explains the procedure for recoding it... and hopefully sticks.
https://www.youtube.com/watch?v=G7YRiVYrLjo
