https://www.audizine.com/forum/showt...tes-Don-t-work However, your mention of the large flashing red warning on the DIS would imply something more serious, as it's only one of four such red warnings displayed on the DIS. Just found another post which said that the ABS loses its coding when the slip ring is disconnected! The following video from Ross-Tech explains the procedure for recoding it... and hopefully sticks. https://www.youtube.com/watch?v=G7YRiVYrLjo
Thanks for the links Sean. Interesting reading.
I spoke to the garage owner who’s an ex D2 owner himself and very familiar with the platform. He has all the Audi dealer spec software and ran through the correct procedures to clear the faults but was confused why the coding was disappearing after the wheels were moved. This thread came to after a Google search and sounds similar to the symptoms he was getting. https://forum.a8parts.co.uk/showthread.php?t=10964 Maybe I need to replace the ABS module/ECU? On a side note, Dolph is driving beautifully now with the correct squib installed…despite the Christmas tree lights all over the dash ![]() Raising the suspension so it’s the equivalent of a 30mm drop plus chunky tyres on the original 18” Avus wheels makes for an epic cruising machine now ![]()
This is what I’m dealing with
![]() Airbag light came on after Christmas…apparently passenger occupancy sensor. Tried the forum “fix” by Andrew but didn’t work for me. ABS & TC lights also came on after Christmas. Will need to fault find these. Headlight level sensor. Appeared after coilovers fitted. Tried good quality used item up front but dash warning still persists. Big red flashing warning error on DIS. New warning from today. No idea what this even is ![]() No one is buying this with all these warning lights ![]()
I believe both of the below items from our forum sponsors fit the D2 S8
Shall I buy them and take it back to DS Autowerkes to fit? https://www.ebay.co.uk/itm/176047602...mis&media=COPY https://www.ebay.co.uk/itm/196091154...mis&media=COPY
Seems to be a more significant issue than the other two lights. The manual just states that it 'indicates a danger', accompanied by three chimes, and to stop the car. The manual also mentions that this warning light can appear if the brake fluid level is too low.
I will double check the fluid levels a bit later Sean (I’m sure Dave would have spotted if it was low doing all his checks)
I think it’s a coding issue or something similar as Dolph is actually driving better than ever right now. The brakes are nice and solid (for a D2 anyway!) Every time I fix an issue with this car 2 or 3 more issues then arise.
https://www.audifans.net/ftopict-33959.html
Another interesting read from an old post on Audifans. Very similar to what I have experienced. I think I will try the ABS control unit replacement first. I’ve messaged our forum sponsors to check if they have one compatible with an S8. By the time it does sell, Dolph will be running better than ever and someone else will get to enjoy it after I fixed all of the issues ![]()
It doesn't want you to sell it. Will be interesting to see what happens next.
