Originally Posted by donp38
water in right side cubby in dash also.
Missed this in your previous post. What/where is this 'cubby'?
copious water sprayed on the boot, then on the roof etc. no evidence of water ingress. hmmm any ideas what next?
Is it just the spare wheel well? i.e. are the two spaces where the battery and amplifier go on either side dry? Is it possible that there is a crack/hole in the spare wheel housing? Also, considering it just seems to be glued in place, maybe some of that has deteriorated. Is it time to put your son in the boot again, and then turn the hose straight up at the bottom of the car?
the front leak is strange, pours in on the drivers side.. cant see the tube by the hinge...
I know on mine that the tube on the drivers side is very difficult to see. I'd be tempted to remove the knee panel under the steering wheel, the fuse cover and also unscrew the fuse box assembly, so you can see as much as possible. Then, when it's dark, park the car nose down and to the right, open the sunroof and then put in a small quantity of water with a UV dye in it. After that, it's a case of using a UV torch to check the inside footwell and sides. Either the drain coming down from the sunroof has got damaged, or worse, become detached at the bottom.
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
Sold!
2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
