D2 - Common Faults Quick links to all known common faults and their solutions |
Hi All.
I have at least two leaks. First the boot is getting water in. The spare wheel well is getting water. second the driver side foot well is getting water. water in right side cubby in dash also. Any ideas? Many thanks. |
For your second one, I'd check out numbers 1,2 & 3 in the same post mentioned above. If you hear sloshing, I'd suspect number 1. If it was the passenger side, I'd definitely look at number 8. In fact, just deal with number 8 regardless, before it becomes an issue.
IIRC, MJ/Michaela/Micky Jane made a batch of the boot cable grommets on her 3D printer. Might well be worth a PM to see if she has any left.
Many thanks.
first time today to have a look. regarding the boot, (we have new MJ gromets fitted) with my son in the boot armed with a torch. copious water sprayed on the boot, then on the roof etc. no evidence of water ingress. hmmm any ideas what next? the front leak is strange, pours in on the drivers side.. cant see the tube by the hinge... both these leaks are really serous... Last edited by donp38; 3rd November 2024 at 08:06 PM. |
Missed this in your previous post. What/where is this 'cubby'?
I know on mine that the tube on the drivers side is very difficult to see. I'd be tempted to remove the knee panel under the steering wheel, the fuse cover and also unscrew the fuse box assembly, so you can see as much as possible. Then, when it's dark, park the car nose down and to the right, open the sunroof and then put in a small quantity of water with a UV dye in it. After that, it's a case of using a UV torch to check the inside footwell and sides. Either the drain coming down from the sunroof has got damaged, or worse, become detached at the bottom.
Great idea.
We will get onto it at the weekend. Many thanks |
I am still struggling.
What do people suggest. Audi Specialist garage or a good body shop ?? |
