Old 14th January 2014, 12:56 PM
Unfortunately yes. You will need to unbolt the speakers, from the boot, as they need to be unplugged and removed to remove the rear parcel shelf.
To access these screws you need to remove the plastic speaker covers attached to the boot roof.
Also, the frame carrying the rear blind is bolted to the boot roof, so you will need to unbolt it from the boot. There should be 3 nuts to remove.
Cheers for that. If it ever dries up, I'll have to look in the boot to see if I can access the speaker bolts, and have a look for where the bolts for the blind would go. I have a copy of Elsawin so will check in that as well.
